Last edit by: IB Advertising
- Toyota 4Runner 1996-2002: Aftermarket Modifications
Overview of popular modifications to help you customize your 4Runner.
The most complete 3rd Gen 4Runner lift kit ever offered: Featuring Tundra TRD coils
#61
It's 1" to 1'5" higher in the rear. It you want to see what your truck would look like use a floor jack and jack the rear up 1" to 1.5". I don't have any driveway pics, but I do have lots of trail shots.
#63
Awesome work Steve! Glad to see you're making it easier for people to get the right stuff the first time!
This is the ONLY way I would go about lifting a 3rd gen, it is the most solid, stable and capable configuration.
Fink
Fink
#65
Originally Posted by spaugh
so running 315's with this lift kit is no problem? Rubbing etc is not an issue? I realize regearing might be necessary, but physically, the 35 inch tires will be ok? That would be really nice although I wonder if this is pushing the limits of the IFS??? anyhow, thanks for providing info in such a timely manner, I plan to build up the runner this summer for use when the temps cool down in fall.
You will have to re-gear.
Pushing the limits of IFS? Probably not as 95% of all breakage is due to the cage getting ripped out from too much droop. That is breakage from stupidity, not a weak drivetrain. Cryo Treat your CV shafts.
This is a nice, simple, solid complete lift it. If you really want to open it up, use the Rubicon Express Joint Links.
#66
All orders placed after 6-1-2006 will include the Tokico Trek > Master R/T front shock, the Tokico Tacoma Double Cab TRD Blue shock will no longer be used.
This is purely a "cost" issue, If I can get the same or equivalent shock that is made by the exact same company aftermarket, that is what we are going to do. As you cut out the TRD/Toyota markup.
Instead of a price increase, as these Toyota parts do continually go up in cost over time, I have switched to the aftermarket Tokico Trek > Master R/T shock. Not the one sold through TRD & Toyota. I have a set of each here and there will be no issues. Any order placed before 6-1-2006 will still include the Blue TRD shocks.
#67
I'm kind of a noob to this kind of a lift idea. Two questions. First regarding the drive shaft. With the LC coils, I'll need to relocate the drive shaft under the tank instead of through it? Is this a major operation?
Second, I've recently purchased new Rancho shocks all around. Extended, they're about 22". Will I need new longer shocks? I've read that if you use shocks similar to what I have, there's no need for longer brake lines because the shocks will limit travel. Is that true?
Thanks!
Thanks!
#68
Thanks!
Thanks!
#69
I'm kind of a noob to this kind of a lift idea. Two questions. First regarding the drive shaft. With the LC coils, I'll need to relocate the drive shaft under the tank instead of through it? Is this a major operation?...
at least you found the right forum to learn from...
#70
Well after spending a week testing and measuring the following:
1. Tokico TRD Blue
2. Tokico Trek Master Green
3. Bilstein TRD Yellow (Toyota Stock, not aftermarket)
4. Old Man Emu N91S
Here is the deal:
1. Old Man Emu is the longest. Too Long. It's also even in the Heavy Duty version, absurdly soft.
2. TRD Tokico Blue shocks ARE without a doubt quite different. They are the longest of the stock shocks and have very clear dual dampening as well as full extension dampeners. Although they look the same, they certainly are not.
3. The Green Trek Master is a plain jane no thrills shock and it appears to be basically the same in length and valving as the TRD Tacoma (Stock) Bilstein.
So I am going to bring the TRD Blue shocks back to the kits. The standard shock is still going to be the Tokico Green Trek Master, but if you want to pay more and upgrade to the dual valved TRD Blue Tokico, you can.
Basically it's a normal shock for the first 1/2 of the way down and then the last 1/2 is considerably stiffer, it also has full extension dampening or some sort of bump stop in it as it is not fully extended until a coil is installed on it.
It's clear to me now why it is a more expensive shock.
If you ordered before June 1 you have the blue shocks by default, don't worry.
#71
Thanks!
Thanks!
BTW...Mine is a 4wd. Thanks for the help.
#72
Ok, I realize a drive shaft doesn't go thru the gas tank...but someone else in a previous post maybe in another thread said you needed to relocate the drive shaft? I did do the Daystar spacer lift myself after all!
No relocating the driveshaft, just that with the lift the driveshaft may hit the gas tank skid under full flex, so some pounding of the gas tank skid may or may not be necessary.
#75
Originally Posted by RTdawgs
Whats the best lift for 33s? I really wanted a 4-5" lift, do you have those?
#76
Yes that would require a Dana 44 retro-fit. Minor welding and some very minor cutting.
#79
Originally Posted by Lone4runner
Steve what exactly is a Sonoran Steel Fabrication L.L.C. FJZ-80 to 4Runner rear shock discs (Four) and what do they do?
#80
i am sorry that i am asking a stupid question i just dont know how they would benefit me in your kit. everything else seems to make sense i just dont know of any discs that go anywhere near the coil springs. any chance you could eleborate. I would very much appreciate it. Thanks
