What locking differential would you suggest
Well id search but it is pretty late. Well I do some recreation offroad and Im just looking for a solid differential that can lock and unlock pretty easily. Drive mainly to school and stuff. Any opinions for something
I know from other sites ill probobly get tolded to search but i will after this one.
yeah the search function shuts down around 11...
looking to go cheap? selectable? automatic? read all about them right here:
https://www.yotatech.com/forums/f31/locker-faq-43572/
and here
https://www.yotatech.com/forums/f31/calling-all-people-lockers-65334/
and here
Theres only 2 selectable lockers out there for the Toyota REAR axle (only one for the front, ARB) Toyota elocker or ARB air locker.
I choose the elocker, and explained it on my site, along with how to retrofit it into your axle
http://www.toyotaoffroad.net/afertig/88/elocker.htm
Originally Posted by CoedNaked
What about an "Eaton" locker?
I love my lockrights in the front or rear if you can handle the wheels being fully locked all the time. Since it seems you're using it mostly for a DD, I'd recommend going with the ARB. That way, you'll also have on-board air. It's a good chunck of money up front but I believe it's well worth it.
Originally Posted by marko3xl3
Unless you want to change out your whole front 3rd, then you could have an e-locker in front as well.
everything else is IFS and has a front differential...
no front differentials can be retrofitted to have an e-locker.
Originally Posted by deathrunner
As far as auto lockers go, I love my aussie locker.
I hear great things about the detroit softlocker, woudl be a bit stronger, but install would cost more.
X2 on the Aussie, we put one in Vince's front end and it was a very straight foward install and works awesome. Shipped to the door for 260.00 Now that's a damn good price for the quality of it. Top notch.
Search more like the others have mentioned and one more suggestion. If people give you a suggestion on a locker...make sure they have ran one before and not just regurgitating what they've read on the net or hearsay.
There are finite differences between all of the different brands and methods of locking a diff and lots to do with driving style and terrain.
HTH
It would help if we knew what kind of truck you have. That can make a difference in what lockers are an option.
bamachem, "differential" doesn't refer to the IFS differential anymore than it refers to the differential located in a solid axles 3rd member. But yeah, no E-locker for the front of an IFS rig.. which we don't know if he has an IFS or solid axle since he hasn't posted details of his rig yet.
Originally Posted by AxleIke
elockers only fit the rear
How did they get it to fit, the front IFS is set up so that you'd have to cut the housing comepletly, and even then it would be hard. Perhaps you are refering to the SA, in which case i would say you are right. But i was talking about IFS which i should have clarified. Sorry
