Warm M8000 wiring help
Old 11-03-2015 | 06:22 PM
Matt89toyota's Avatar
Traded some trail gear front springs for a warm m8000 and thought I had it all wired correctly but it won't spool in or out. No noise whatsoever. I've tested the motor directly with the battery and it works great. This is the wiring for the solenoid. I'm hoping it's just some crossed wires.
Old 11-03-2015 | 06:46 PM
dropzone's Avatar
Fossilized
You will find what you need here
https://www.warn.com/truck/winches/src/M8000.shtml
Old 11-03-2015 | 08:57 PM
Not the same style solenoid. I've wired it like the diagrams I've found online. Still nothing all connections are tight but can't figure it out.
Old 11-05-2015 | 01:14 PM
wyoming9's Avatar
Red face
Have you checked that your control does in fact work ??
Switches not working ??
Open control cable ??
You have checked the solenoids do in fact work??
You really did not expect to get a Winch that worked ??
Old 11-05-2015 | 03:36 PM
I've seen it work before, it's winched me out before actually. I got it from my uncle. I got a diagram from warn and wired it exactly the same as it is from them and still nothing. I haven't checked the solenoids yet but I'm guessing that's the problem.
BigHoss_27
10-13-2015 09:15 PM
PT3
3.4 Swaps
10-13-2015 10:39 AM
ashamsuddin
10-12-2015 04:27 AM
JimiJams
9
10-08-2015 01:15 PM
JookUpVandetti
10-08-2015 12:27 PM
