stupid dumb newb question
if i change my gears over to 4.88 front and rear and then say, a year from now do the SAS, I have to change my front gears again, correct?
Mike
The front and rear gears have to match...otherwise the front tire(s) would spin at a different speed than the rear. Toyota didn't put 4.88's in a front SA (that I know of), yes, you'd have to swap the gears out in the new SAS as well.
I have heard of some folks running different gears, front and rear, temporarily. But I wouldn't recommend it.
what i mean is, are 4.88s in the ifs are different from 4.88s in the solid axle? i couldn't just use the same differential, could i?
and it's a 4 cyl with 33s
The gears will be a different size. You will just sell the IFS stuff to someone here who needs new stuff or wants the gears, already set up. You should be able to recoup some cash that way...
Originally Posted by gwhayduke
I think the front diff on an IFS is a 7.5 inch. Isn't that the same as the front diff on a SA?
