Gear Lube with ARB's?
Old 01-13-2005 | 04:49 PM
justinh's Avatar
What gear lube is everyone running with their ARB'd differentials? I assume that any regular lube will be fine. Just want to be sure before i toast $2000 worth of gears and lockers
Old 01-13-2005 | 04:55 PM
GRNTACO's Avatar
I run the Amsoil Series 2000 75-90W. No problems here. Be sure you do the diff breather extension if you put high dollar oil in the rear diff...........so you don't ruin it with water.
Old 01-13-2005 | 07:02 PM
justinh's Avatar
thanks, i have done the rear breather extn quite some time ago.
Old 01-13-2005 | 07:06 PM
Robinhood150's Avatar
Yeah, regular gear oil is fine. No additives needed.
Old 01-13-2005 | 07:09 PM
justinh's Avatar
thanks, that is what i was hoping to hear, i didn't want to get something that would damage any of the seals or o-rings and since i bought used thirds already set-up didn't get much packaging or direction.
Old 01-15-2005 | 10:02 AM
4Crawler's Avatar
I run Redline heavy weight shockproof gear oil in mine:
http://www.4crawler.com/4x4/index.sh...ntheticGearOil
Old 01-15-2005 | 10:04 AM
waskillywabbit's Avatar
I am running the local auto parts brand gear oil right now during the break in period as I'll end up trashing it in a month or so anyway, then I'll put in some high dollar synthetic crap.
Old 01-16-2005 | 08:57 AM
Arnold's Avatar
I run Redline synthetic 75W-90 gear oil. For added protection I use magnetic diff fill plugs and clean 'em out every time I change my engine oil.
justdifferentials
Just Differentials
09-17-2015 07:14 PM
nick9455649
09-11-2015 06:10 PM
coffey50
07-28-2015 11:55 AM
altydog
07-28-2015 11:20 AM
A2theK
07-12-2015 11:46 AM
