Ever see a Long Travel 1st gen 4Runner?
Allright guys,
I got the front end of the Deathrunner mostly complete. I got it from Protrux just in time to take it to Ocotillo on Saturday (sorry no pics). This setup absorbs impact far better than the stock setup, and my articulation is insane compared to stock.
I still need to get everything dialed in. Obviously it needs paint, but not until the rear glass is on. Here are some pics, let me know what you think. I'm stoked. -Seth
Oh yeah, before I get any comments about my tire "mullet" action. You know business in the front party in the back.
My 33x10.50 rears were to bald to go to ocotillo with, so I put on my 12.50s with good tread.
JD fabrication makes that kit.JD Fab
Truck looks great!
We are just wrapping up a 3.4l swap for our '89 'Runner, then the new Total Chaos coil-over "Caddy Kit" goes in up front with a custom rear that will also pull about 13" vertical without cutting into the cab.
Keep up the good work and keep the pics coming!
Truck looks great!
One option for the rear glass is to get quarters from Toyota Fiberglass (YotaTech member!) and trim it up a few inches, then mini-tub the inside to clear whatever tire size you settle on. I'm sure Hanneman or Glassworks or somebody makes something already or you could graft some same model truck bedsides in otherwise.
Yeah, It's a JD Kit. Nice stuff. I'm pretty happy thus far.
Fot the rear glass, we will be working with hanneman to either adapt an 84-88 long bed pickup side, or worst case scenario make a complete custom.
We are going to cut out as much fender as possible (While still keeping a seal) and then we will fasten the glass over the side with zeuss (Is that right?) fasteners.
There has been discussion of putting some sort of rubber on the edges of the glass, so that my buddies don't get glass splinters when they ride in back and hang thier arms out the window.
Marc P -We're probably going back to ocotillo in the next couple of weeks. Season is coming......
My torsion bars are finally settling in, so I need to adjust my height again.
Thanks for the comments.
Pinnacle- Jim at Protrux seems to think that the long bed pickup sides can and will work for a 4runner. I have seen the 2nd gen glass by fiberworks and it looks sweet. There is a 2wd white 2nd gen at protrux with it.
What is fiberworks web site??
For those of you wanting more pocs, yet not savvy enough to navigate my photobucket page, here's the rest.
http://photobucket.com/albums/v373/D...urrent=jd3.jpg
http://photobucket.com/albums/v373/D...ent=08-211.jpg
http://photobucket.com/albums/v373/D...t=b61cc649.jpg
http://photobucket.com/albums/v373/D...t=ad3e51c1.jpg
http://photobucket.com/albums/v373/D...t=b119859d.jpg
The following users liked this post:
SomedayJ (12-30-2019)
I was just over at Total Chaos yesterday to get some information on their new steering linkage kit. It's quite beefy and will hold up to my pounding them on the rocks, I should be getting this next week. While I was there they showed me the Caddy kit for the earlier rigs. They came up with a new design that eliminates the torsion bars and has the ability to use dual shocks. This is a much needed improvment, those brackets that attach the bars to the upper A-arm are the weak link.
Originally Posted by FSRBIKER
There is a company that makes 1st Gen 4Runner steel quarters, i'll have to find the link again but the cost was about $255 per side.
http://alfaparts.net/toyota4r.htm
WOW $20 shipping!!
FSRBIKER- Good eye on the site, but the bedsides we are talking about need to be larger than stock. "Bulged out" so to speak. Thanks though.
Pinnacle- Prtotrux won't do me wrong on the sides. Wait and see how my rear looks when I get it done. You might like it, and then it could be 4runner time for you too.
Bruce- I too heard about the new chaos kit, but I think thier lower arms will probably remain the same style. I went with JD because of the sheer strength of the lowers. Also the geometry does a better job of keeping the lower bjs in place.
I have never heard of any problems with the torsion socket on the A arm, but maybe I haven't read enough. Regardless, the kit I have allows for the use of a coilover while still keeping 4x4.
I'm gonna run the torsions for a while, and if I decided to (or if I have money) I can change to coilovers. My sway away shocks are already threaded for it. All I have to do is get the springs and kit, brace my two shock hoops together, and possibly change the location of one of my shock tabs.
I have seen plenty of 1st and 2nd gen's holding up with torsions and kits by ESB, Chaos, and JD. The big advantage of the coils to me are the ability to adjust spring rate without affecting height. I also imagine coils articulate better than t-bars (although I am pretty satisfied with the t-bar flex)
I really need to get my Rear setup now, I went beating around again yesterday and my front end takes it all, but my rear bucks on the big bumps. fun stuff
Sounds good, I cant wait to see what the sides will look like. I probably wont be getting anyting until the begining of next next year, so I have some time to shop around for everything.
I know someone who has broken the t-bar socket, he bought his 'runner without 4wd, he ditched the t-bars and went with a coilover
I checked fiberwerks and they only have 2nd gen.......but they will custom make stuff. I emailed them about mine and I will keep y'all posted on how that goes. I like to examine all my options first.
Pinnacle- Was there any major damage? I imagine that worst that could happen is to be riding on nothing but bump stops. Not favorable, but definitely not the worst thing that could happen. I'm going to see if there are any upgrades for this part. hmmmm
