Crushed 89 single cab-swapping for 89 extened cab.
Hey i have found lotsof usful info on yotatech finally had to become a member. I rolled my truck twice in 2 weeks now, also my daily driver. A few questions i have are will the extended cab bolt onto my single cab frame? I am gonna build a flatbed for it. Can i leave motor in frame when i do this? Hell what cant i leave on the frame? The extended cab is electrial is uknown, but all single cab is fine. I have to change gauges cluster and such [missing from exrended cab]. Extended cab was on a V8 build. I am a profesional fabricator/Ironworker/millright. Just not to savy on what im about to do i realize i could do on some body work and be rolling again but i already bought other cab all mechanical is sound one ruptured soft brake line. Thanks. its gonna be at least 4 weekends before this is completed, maby 3 with the right knowledge.
If your a Mill wrong you can figure it out!!
The rear cab mounts might have to be moved I forget without looking
it is your project if you want to leave every thing on the frame go for it then if it is in the way you can remove it
Fess Up just how did you roll your truck twice ??
Maybe if you plan on more roll overs just drive what you have!!
Like wyoming said, the rear cab mount is moved farther back on the ext cab and I believe the crossmember for the gas tank is also going to interfere with the bottom of the cab. You will also have to take out about a foot out of the front of the bed. I have seen one done that way and considered doing it myself, but it looks kind of goofy and not proportional at all.
$$ lots of it ill never get back
Thanks wyoming, way to discredit and entire breed of workers . I figured it out though, not bad for a knuckledrager. I have the cab harness swapped and will be assembling the dash tomorrow. I realized the cab mounts are different but there is a bolt location on the excab that matches the single cab mounts. So i am gonna set the cab on it to locate new mount location. Also i anticipate at least 2" body lift + 4" suspension and then i dont have to flip leafs around to move rear axel away from cab. More work than i originally thought but to late to turn back. Ill keep posting pick and reference anything major i encounter. Rollovers= i quit smoking pot and had to find a neww high [ADRENALINE] seems to be more expensive so far. But my hands dont go numb anymore. First time 40mph logging roads into a swamp no big deal 1 1/2 rolls. Second time 45ish mph 1 1/2 rolls stayed on hardpack 1" pitrun less forgiving, twisted testical, glass still stuck in my elbow causing infection antibiotics working but have to see surgeon on wedensday.
Had costom fit for chevy automatic trans
So take what u need and make it work
Chainfall was the ticket. The winch was a fail and my head still hurts.
I did take it as a compliment. If u ask me a good metal worker can do it all doesnt matter your job title, unless your union.hahaha
I hate aftermarket parts never close to oem
Cab mounts moved . I elevated the cab mounts 3 3/4" so they didnt interfere with anything and ill use square tubing as body lift on other 4 mounts and probably a flat washer here and there to compensate for twisted frame
instead of a 2" body lift you mentioned, i've seen some people tub the back of the cab for tire clearance. i think there area few builds floating around the internet for xcab on single cab frames, most of them are Tacoma-based I believe, but same concept.
1 more week at least and it will be wheeling
3"x 2"x 2"X 4 squaretubing and 3/4" X 4 rock crusher belt, leftovers from work. 7" bolts, and i have a body lift. 7/16" holes
chriscorpus
77
02-25-2019 01:50 PM
chicago60647
05-10-2016 12:59 AM
kidzilla7x
7
04-23-2016 12:20 AM
