Body and suspension lift are done
Old 04-25-2005 | 02:59 PM
Guerrero's Avatar
Talking Body and suspension lift are done
1” Body lift from 4crawler.com (Thanks Roger)
Lifting the body, putting the 1” blocks, and the steering shaft extension was a piece of cake, took me about a 3 hours, taking my time. To install the front bumper, was a pain…took me forever. I got the 1” bracket for the cosmetic bumper, but the 00-02 have an inside bumper “the real bumper” and have couple options to lift it, after trying to figure it out how I was going to do it, I just bolt it to the stock position in a little angle. I was able to bolt the two bottom bolts, but not the top one. I’ll take some pics later. If you get a 1” Body lift you can install the inner bumper in the stock location.
OME Suspension lift
OME N91S Front Shocks
OME 881 Front Coils
OME N86 Rear Shocks
OME 891 Rear Coils
Installation for the rear was very easy. The front was all right the hardest part was to compress the OME881 coils. It took me about 8 hours to installed the whole suspension. I borrow the spring compressor from AutoZone.
Wheels
Centerline Hellcat Style 34, 16x8 Polished Aluminum Rims. I think backspacing is 4.5 the tires are BFGoodrich Mud Terrain KM size 285/75/R16.
The rig looks hot, love the OME suspension and wheels, but I hate the performance. I knew that after putting those big heavy wheels I was going to loose some performance, but I never thought it was going to be that much, I can always fix that
Old 04-25-2005 | 03:00 PM
jimbo74's Avatar
Guerrero's Avatar
Thumbs up Pics
BEFORE
1” BODY LIFT
AFTER
Old 04-25-2005 | 03:05 PM
Strap22's Avatar
Sponsoring Vendor
Looks great!
Old 04-25-2005 | 03:07 PM
Guerrero's Avatar
Question Questions
If I re-gear my rig, what are the new gears I have to go with? 4.88?
I’m not sure what gears I got now, but I think I have a 3.3 / 3.42 gears.
My Vin plate A/TM #s:
A01A/A340E
Do I need a PanHard Drop and Parking Brake Bracket?
What is the speed rating for the BFGoodrich Mud Terrains?
I need to do an aligment, but before I go to any shop, where should I take it?
I'm in San Diego.
My tires are rubbing against the Upper A-Arm. I guess, I can shave them a little, but if I do that, am I going to have any problems?
Old 04-25-2005 | 03:30 PM
Crux's Avatar
Hmm... can't see the pics
Old 04-25-2005 | 03:33 PM
r0cky's Avatar
i can't either.
Old 04-25-2005 | 03:36 PM
Guerrero's Avatar
How can I post pictures?
I used [IMG]link[/IMG], but I just got the links.
The pics are hosted in my pictures\yahoo
Old 04-25-2005 | 04:02 PM
Crux's Avatar
Well I'm not sure how yahoo works, but your links are not direct links to image files (.jpg). There seems to be some kind of php stuff going on
Old 04-25-2005 | 04:04 PM
jethro's Avatar
Originally Posted by Guerrero
BEFORE
1” BODY LIFT
AFTER
Maybe it's just me, but only your last two "after" pics are working.
Lookin' good from what I can see though.
Old 04-25-2005 | 04:25 PM
2wheelBLACKOUT's Avatar
pics not workin' for me..i really wana see!!
Old 04-25-2005 | 04:52 PM
Rollindamud's Avatar
try posting them in www.imageshack.ws
Old 04-25-2005 | 05:10 PM
JETSI's Avatar
not working for me either.
Old 04-25-2005 | 05:18 PM
Guerrero's Avatar
I just host them there.
Thanks
Old 04-25-2005 | 05:49 PM
4Crawler's Avatar
A01A/A340E
I'm in San Diego.
Speed rating, look up on the tire sidewall to find out:
http://www.4crawler.com/Diesel/Tires.shtml#SpeedRating
Tire rubbing, a wheel spacer 3/16" to 1/4" would fix that as well.
For new gears, to restore to stock effective gearing, take new-tire-size / stock-tire-size * stock-gearing = new-gearing.
Old 04-25-2005 | 07:06 PM
leebee's Avatar
pix work for me, looks great! follow rogers link and get ready for a few more dollars to disappear from your wallet! if you decide to change wheels you can get them with the correct back spacing to eliminate the rubbing issue with the 'a' arm. 4crawler.com has a pretty comprehensive site with lots of info, dig around and you will find more info on just about anything you could want to do!
lee
Old 04-25-2005 | 07:17 PM
looks great, just needs some mud now
Old 04-25-2005 | 07:36 PM
AznSky's Avatar
I have the same problem with the a-arm rubbing, I grinding some of it down, but it still get REALLY close when I flex. And that's without airing down.
So I'm probably gonna go with 1" wheel spacers. Just make sure you get the one with studs, no slip on spacers.
looks hot.
Old 04-25-2005 | 08:27 PM
Guerrero's Avatar
Front bumper installation pics
I have to trim the a piece of the outter bumper bracket to be able to bolt the bumper
I have to cut I little piece of the stock bracket to be able to fit the bolt that is going to hold the outter bumper
Only the bottom two bolts are holding the inner bumper
Old 04-26-2005 | 04:31 AM
JETSI's Avatar
looks good, nice job
