which is better?????
Which is a better locker? The Toyota E-locker. Or the ARB air locker. Thought bout buying the complete 3rd's from the local Toy dealer. Factory 4.56 gears. But at barley over 1K each they sound expensive. On the other hand, ARB's are about 650 each. Plus I need an air supply. Along with R&P gears. In my opinion, I think that the E-locker would be the way to go. Just wondering what everyone else thought
You'll probably get better responses for your off road questions in the off road sections.
Both are very good lockers, most people say they're about equal in strength and reliability.
you can get the e-lockers for less than a $1,000 each. Check Marlin and Inchworm and there used to be a few toyota dealerships that sold them for around $750 i think.
Originally Posted by Jake94
eLocker $795 (came w/ 4.56 gears) + Home made ECU, wiring and, Harness from toyota $60 + Rear axle modification $200 = $1055
Jake.
Jake.
I like the ARB because then it gives you an excuese to get on board air at the same time.
I have yet to do a lot of digging for a deal on those thirds. Or any for that matter. Too many other things to buy first (bilsteins,crawl box, hy-steer,fab up some sliders,etc.) I'm pretty much in the first stage of my project 83 trail tamer/daily driver. Just thought those E-lockers would kick arse. plus I've heard that ARB's can leak air pretty easy. if the fittings aren't in tip top shape. I work with all kinds of air fittings like those. And over time they do fail. well the lines do at least. don't know what ARB uses but it seems that grease and oil will eat the ones at work over a period of time.
I went with the e-locker and am very happy with it. I paid $400 shipped for a used e-locker, $325 for 5.29s installed, and about $75 for wiring and misc. parts (did the housing mods myself). Total $800...not too far from what an ARB would run. Either one will be reliable, but if the e-locker has a problem, you can pull the motor (3 nuts) and slide the shift fork over with a screwdriver and have it locked. If the ARB leaks, you're open. Another option would be to buy an e-locked Tacoma axle ($800-1000 probably), and then sell your existing axle.
