Any "non clicking" disco's available for 2nd gen ?
As my 93 is now my daily driver, I want to make it handle a little better but not comprimise off road ability.
On my 99, I went with an Addco fron sway bar which was a night and day on keeping the truck flat after I lifted it and Nuke Disco's which were super quiet all the time.... unlike some others :cry:
Whats the skinny on 2nd gen Disco's up front ... I searched but I really want your input on how they are on the road.
Thanks
David
Thanks
David
Originally Posted by 4Crawler
Here is essentially the same type disconnect:
http://www.4crawler.com/4x4/CheapTri...#DisconnectsV2
Not sure we all would do if you were not out there 24/7 putting this stuff together.
David.
P.S. Does anyone ever hear from NUKE ?
That type won't work with the 93 4runner's front sway bar because the bar is different.
You can probably adapt it so that instead of a pin-pin connection you have a pin-eye connection with a rod end. Use the rod end on the disconnect itself rather than in the sway bar hole (shown above).
Edit: I see that Roger has a "right angle adapter" available which would make it work.
I made a similar kind of discos than yours, Steve.
I'm tired of bending or loosing the clips in strong turns in the road...
I drive half the time with one side disconnected, is not as bad as having both and it's better offroading than having both sides connected hahaha.
David
David
kawazx636
10-06-2021 03:03 PM
charlie_fong
09-27-2015 10:06 PM
Toys4parts
09-26-2015 01:56 PM
