adding a body lift to a 3'revtek susp.?
adding a body lift to a 3" revtek susp.?
hey i was just wondering if i could add a body lift to my 3" revtek suspension lift? would i have any problems or can it be done?
thanks
justin
'97 tacoma v6 3.4L, k&n fipk, 3" revtek susp., 32x11.5x15 bridgestone dueller a/t
thanks
justin
You can do it! And you can do it all by yourself! Roger Brown makes the best body lift kits: http://www.4crawler.com/4x4/ForSale/ProductLine.shtml
Be sure to order from him...everyone on this forum will assure you he is the man when it comes to body lifts.
I'm running a 2" BL on my 97 4runner. I have revtek 3" on with it. The body lift doesnt affect the suspension lift at all. The only problems I've had are with the revtek lift fading. I have to get new coil or go with a whole new adjustable coilover set. I have pics of what it looks like on my web.
Body and suspension lift info:
Body Lift Kit Pricing Info:
http://www.4crawler.com/4x4/ForSale/BodyLiftPricing.txt
Code:
95.5-04 Tacoma (all models) Body Lift Kit: Kit: Cost/1" Cost/2" Cost/3" B $ 52.00 $ 66.00 $ 80.00 (Ult. blocks only) D $ 77.00 $ 91.00 $105.00 (Kit B + h/w only) F $ 87.00*** $101.00*** $115.00*** (Kit D + front bumper brkt) SE $ 25.00 $ 32.50 $ 40.00 (Steering shaft Extension) BS* $ 8.00 $ 10.00 $ 12.00 (Per pair of bed spacers, 1 pr.,2 on longbed) RB* $ 5.00*** $ 5.00*** $ n/a (Rear Bumper h/w kit) P* $ 75.00 $ 75.00 $ 75.00 (Poly body mounts - '95.5-'00 only) COLOR $ 12.00 $ 12.00 $ 12.00 (Custom color lift blocks) HD $ 15.00 $ 15.00 $ 15.00 (Upgrade Gr8 Hardware, rec on 2"+) SL n/a $ 15.00 $ 20.00 (screw-on Shift Lever extension, $/ea.) -------------------------------------------- Typical Kit $125.00 $148.50 $167.00 + shipping** F+SE+BS+RB F+SE+BS+RB F+SE+BS (Typical kit contents) Note: 3" lift may require extending gas tank filler hoses, see: http://4crawler.com/4x4/ForSale/Docs...To.shtml#Hoses
See above referenced file for description of the kit letters
Kits B/D/F/H are mutually exclusive, that is kits F and H include kit D/B
(*) Optional, subtract from kit price if included and not needed
(**) Zip code/country needed for shipping and sales tax calculation
(***) Requires drilling, 2"+ flip stock bumper brackets & redrill holes
Front bumper bracket on 2000+ 4Runner/2001+ Tacoma, will need to remove
or raise the inner bumper for the outer bumper to clear when lifted
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
Backcountry411
07-24-2015 08:06 AM
