99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
2000 tundra disconect day time running lights
Old 03-16-2005 | 04:56 AM
stubb's Avatar
How do you disconect the day time running lights on a 2000 tundra SR5 4wd ?
Old 03-16-2005 | 07:19 AM
Beartracker's Avatar
Why would you want to disconnect them? It's a great safety featuer and if it was up to me everyone would have to drive with there lights on. Mike
Old 03-16-2005 | 07:42 AM
Why would you want to disconnect them? If it was up to me everyone would have to run with them on 24 hours a day. They are a great safety feature but for some reason some people don't like to have there lights on. I sure can't figure out how it's hurts anything on my vehicals and it does help people see me in low light areas. Mike
Old 03-16-2005 | 07:44 AM
Lefty's Avatar
I'm a bit rusty on this mod, since I did it 3 years ago and no longer have the truck. However, I believe there is a connection on the driver-side fender in the engine compartment that allows you to disconnect the DRLs. If I remember correctly, the connection from the headlights splits into two wires just behind the driverside light. One wire heads to a ring terminal connected to the inside of the fender just behind the battery. There should be a disconnect on this wire. You should simply be able to disconnect that wire and disable the DRLs.
HOWEVER, before using my instructions, I suggest you head over to Tundra Solutions and search for the mod. I know I got the instructions from that site back when I had the truck.
Good Luck !
Steve
Old 03-17-2005 | 08:29 AM
Mohamed's Avatar
I too love my DRLs on my Tundra and I keep them on.
The plug is as Lefty stated on the left side near the shock/strut area (although located on the side fender wall) and is grey.
Old 03-17-2005 | 09:32 AM
My DRL's don't work (bought the truck at 61k, it's an 03)... ideas?
Old 03-24-2005 | 08:09 PM
BikKat's Avatar
There are many reasons to disable DRLs, my biggest gripe in the inability to signal trucks on the highway that they can some over in-front of me. To signal moron drivers to turn on their head lights when they are too stupid to figure it out on their own. To use fog lights in a extreamly foggy situation, you want to put the smallest amount of light on the fog as possible.
SLG
Old 04-05-2005 | 05:52 AM
stubb's Avatar
Thanks for the info. Mohamed. You were right.
gillesdetrail
11-19-2019 01:56 PM
Mutinebullfrog
06-18-2015 02:36 PM
88Toy
7
06-17-2015 10:40 AM
infinityisfive
06-16-2015 07:51 PM
