Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
solid axle birfield re assembly
Old 11-15-2015 | 09:47 PM
shmulikt's Avatar
Hello good people .
I'm new around here, but heard good things about this site so i decided to try here .
I've almost completed the rebuild, ratio swap and ARb's on my LC105 (which is a solid axle 100 similar to the 80) but got stuck after disassembling my birf completely. I'm not sure which way the inner and outer parts and balls should sit.... the inner ring is slightly more tapered on one side and stuff like that....
I've spent hours searching the forums here, but failed to find a description of the inner parts of the joint . most threads are on replacing the entire birf or removing the shaft . BTW the FSM has nothing to say about it .
help would be greatly appreciated.
Old 11-16-2015 | 01:52 AM
dropzone's Avatar
Fossilized
I hate to point you to another forum but to be honest you might have better luck with this on
IH8mud.com
jmoua
03-29-2023 03:42 PM
ZGjethro
06-07-2017 11:04 PM
irv
09-29-2015 06:20 PM
elaketiger
09-14-2015 09:58 AM
Quick Reply: solid axle birfield re assembly
