Give your Toyota an offroad character with Go Rhino Element Bumper
FormerVendor
If you plan an off-road trip that involves technical trails, the Element Bumper by Go Rhino is a must! It will maximize the front-end protection of your latest generation Toyota Tacoma and improve its capabilities. The bumper is manufactured with outstanding durability in mind from the 14 gauge ⅛’ steel covered with the black powder-coat finish for maximum corrosion resistance. It comes with application-specific ¼’ mounting brackets for hassle-free installation.
Go Rhino - Element Bumper
Fits: 2016-2021 Toyota Tacoma Double Cab
Notes:
Some assembly is required. Trimming of front fascia required for Tacoma application
Lights sold separately
Features:
Find out more about the new Go Rhino release in this write-up: https://www.carid.com/go-rhino/news/...eady-here.html
Notes:
Features:
- Dramatically improves factory appearance of factory light trucks
- Off-road capability with additional tire and ground clearance
- Mesh panels reduce weight and improves air flow
- Mesh panels are paintable for a customized look
- Multiple light pods can be added to each wing behind mesh panels
- 14 gauge 1/8" steel shell with 1/4" steel mounting brackets and exclusive
- Dual function tow hook mounts
- Light-ready with a static mounting plate for a 20” double row LED light bar (light sold separately)
