Toyota Gear Packages - Just Differentials
Old 05-11-2016 | 02:26 PM
ozzir70's Avatar
Are your gears 2 cut or 5 cut?
Old 05-29-2016 | 10:43 PM
justdifferentials's Avatar
NITRO Gear Packages are always in stock at JustDifferentials.com!
Old 07-13-2016 | 10:47 PM
When was the last time you checked your gear oil? This 10 bolt rear end came in from a local customer. Don't forget about your axles when you are performing routine maintenance on your vehicles!
Old 08-13-2016 | 05:53 PM
The little guy is a Toyota 8 inch pinion gear. Big one is a Nitro 11.8 AAM pinion gear going into a new Chevy. We stock them both should you be ready to regear everything from a mini truck to a seriously built HD diesel. Give us a call at: 866 349 6801 or email us at: info@justdifferentials.com if you have any questions or can't find what you need at: JustDifferentials.com
Old 08-21-2016 | 06:43 PM
  #25
A huge shout out to Canguro Racing for a first place finish in the 8000 class at the Vegas to Reno desert race this weekend! Check out the link to a short video below to see just what their suspension, NITRO gears and axles go through during testing.
Facebook Post
Old 10-29-2016 | 02:39 PM
  #26
Re-gearing your Toyota or other 4x4? We stock gear packages for all the common 4wd platforms including the new 2016 Tacoma gears those trucks so desperately need after a lift and some bigger tires.
Click THIS link to order you gears today or call 866-349-6801 and speak with one of our differential experts!
Toyota Gear Packages - Just Differentials-ugkqtrbm.jpgToyota Gear Packages - Just Differentials-i2kzsucm.jpg
Old 11-04-2016 | 06:25 PM
  #27
November Gear Special!
Order any Nitro Gear Package and receive 10% off on up to 2 lockers, LSD units, spools or chromoly axle kits and more for your rig. Take advantage and save hundreds on gears, lockers, and axle upgrades now. This is not an online special so call 866 349 6801 and speak with one of our differential experts for an ideal combo for your rig!
You can see all the gear packages HERE.
Toyota Gear Packages - Just Differentials-ov4r0ygm.jpgToyota Gear Packages - Just Differentials-jvzosuwm.jpg
Toyota Gear Packages - Just Differentials-pvgujwvm.jpgToyota Gear Packages - Just Differentials-boqv53tm.jpg
Old 12-19-2016 | 01:31 PM
  #28
The NITRO Tacoma Gear Package was featured in Outside Magazine. Here is what they had to say about it:
Nitro Gear Package Kit ($1,360)
You sacrifice performance when you add larger tires and more weight to your truck. The best way to improve that performance is to regear, which means adding a different gear ratio to your front and rear differentials. Adding these new ratios prompts your engine to run at a more efficient RPM, which ensures you get full power on the freeway and off.
You can check out all our Gear Package Kits here:
NITRO Gear Packages
Old 01-15-2017 | 09:23 PM
  #29
It's not just trucks with big tires and rock crawling that break diffs check this out! We have axle housings and third members in stock for the swap to avoid this. Check it all out at JustDifferentials.com
Think you won't break your differential? This happened on a stock 07 tacoma with pretty low miles. 05-15 Toyota Tacoma's with the factory locker are equipped with this tiny 8" diff. We often swap them to the much more robust 8.4 (the oem non-locking rear) with an aftermarket locker. As you can see here the left carrier bearing has spun on the journal so it slides on and off. What this did is loosen up the preload to allowing excessive backlash. The condition is amplified under heavy load, as the pinion forces the ring gear away, which eventually lead to this catastrophic failure.
Old 02-26-2017 | 09:17 PM
  #30
Our Gear Packages include everything you need to regear both your front and rear axles with high quality parts. They include Front and Rear:
-Ring & Pinions
-Master Install kits with bearings, shims, seals, etc (MK)
-Solid preload Spacers if available (noted as SK in description)
-Pinion flanges (if noted with YOK)
Old 04-09-2017 | 03:33 PM
  #31
Do you want 10% off a NITRO Gear Package?
Buy 1 ARB Air Locker and get a free ARB CKSA12 compressor. Buy 2 ARB Air Lockers and receive an ARB CKMA12 compressor. If you buy 2 Air Lockers you will get the CKMA12 compressor and a 10% discount on any Nitro Gear Package.
To get the Gear Package discount call 866-349-6801 or email Info@JustDifferentials.com for a quote. Check out the link to the video below explaining the promotion!
Facebook Post
Old 05-26-2017 | 08:01 AM
  #32
10 great reasons why you should choose JustDifferentials.com when you're in need of gear or axle parts:
1. Quality Parts.
2. Fast Shipping from 2 warehouses.
3 Huge inventory.
4 Skilled differential experts to help you get the right parts the first time.
5. Name brands including: ARB, Nitro, Eaton, Auburn, AAM, Dana-Spicer and more.
6. No Chinese bearings.
7. Competitive Pricing.
8. Wholesale discounts.
9. Complete custom assembled 3rd members built to your spec.
10. Small town service.
Ph: 866 349 6801
Email: info@justdifferentials.com
www.JustDifferentials.com
Old 06-18-2017 | 05:39 PM
  #33
Need some new gears? A locker or two? Maybe some new chromoly axle shafts? We have it all at JustDifferentials.com or you can always call us at 866 349 6801 if you have questions about what to order.
Old 07-22-2017 | 11:08 AM
  #34
Working on something out of the ordinary? Not sure what parts you need? We are here to help! Give us a call at 866 349 6801 or email us at info@justdifferentials.com and a member of our team will help determine what you need. We stock gears, lockers, axles and all the parts in between to help finish your project.
Old 09-01-2017 | 12:27 PM
  #35
It is hard to overstate what a difference correct gearing makes. Heavy back country built rigs almost always need a gear change to perform at an optimum level even when equipped with smaller tires. It is simply one of THE most significant upgrades you can do and unlike most changes, re-gearing benefits you EVERYTIME you drive your rig. On or off-road. If you have any questions you can email us at info@justdifferentials.com or call us at 866 349 6801. You can click the link below to see all of our gear packages:
It has been over one month since we had Nitro Gear & Axle change the gears in our truck. She doesn't have huge tires, but she is 6200 pounds. The truck is so much easier to start from a stop with way less clutch involved. It's awesome. It's also super nice on the hills. It's still a 2.7 and will never be a rocket, but the motor is not working nearly as hard. If your thinking about it, just do it. You won't regret the swap.
Old 09-16-2017 | 07:58 PM
  #36
Another testimonial about how important having the proper gear ratio is, from JKS Manufacturing:
The JKS 4-door was great, right up to the point those awesome 37" Nitto Tire got installed with the stock gears. Nitro Gear & Axle took care of that problem and more. 4.88's, set up kits, a carrier and even those BEEF differential covers. Problem solved, and now we are fighting over the keys!
Old 09-19-2017 | 01:27 PM
  #37
Now is a great time to order new gears, or a NITRO Gear Package Kit. We have tons of inventory in stock! Ask about bundled deals when you order gears and lockers, posi unit or axle shaft kit. Call 866-349-6801 and speak with one of our differential experts today.
voiddweller
19
05-02-2016 10:10 PM
vasinvictor
01-20-2016 01:39 PM
YotaLogic
12
11-17-2015 07:27 AM
ACZR
06-23-2015 08:55 PM
TheManOutside
06-18-2015 04:32 PM
