Toyota Gear Packages - Just Differentials
At Just Differentials we carry gear and axle accessories for nearly every vehicle out there. We work on developing and stocking the hard to find parts, or gear sets, so you can make one call to find everything you need to repair or replace parts in your axles.
Our Gear Packages include everything you need to regear both your front and rear axles with high quality parts. They include Front and Rear:
-Ring & Pinions
-Master Install kits with bearings, shims, seals, etc (MK)
-Solid preload Spacers if available (noted as SK in description)
-Pinion flanges (if noted with YOK)
Check out all of our Toyota gear packages below. We have gear sets for many more vehicles then are listed on our website. If you need a quote or have a question, send us an email or call us at the number listed below. We only made a small number of our gear sets into packages with a single part number. So if you don't see your vehicle, don't worry, we can still help you out. Just give us a call or email us and we will take care of you!
1991-1997 Toyota Land Cruiser 70 & 80 Series Front & Rear Gear Package Kit:
4.56
4.56 with OE lockers
4.88
4.88 with OE lockers
5.29
5.29 with OE lockers
1998-2007 Toyota Landcruiser 100 Series Front & Rear Gear Package Kit:
4.30
4.30 with oe rear locker
4.88
4.88 with oe rear locker
2008-Present Toyota Land Cruiser 200 Series Front & Rear Gear Package Kit:
4.88
Toyota Landcruiser II, Bundera LJ, RJ, KZJ 70/73/78 Front & Rear Gear Package Kit:
4.30
4.56
4.88
5.29
07-09 FJ Cruiser, 03-09 4Runner Prado 120, 05+ Hilux Front & Rear Gear Package Kit:
4.56
4.56 with OE rear locker
4.88
4.88 with OE rear locker
2010+ FJ Cruiser, 4runner, Prado 150 Front & Rear Gear Package Kit:
4.56
95.5-04 Tacoma, 00-06 Tundra & Sequoia Front & Rear Gear Package Kit:
4.56 without Rear locker
4.88 without Rear Locker
5.29 without rear locker
05+ Tacoma Front & Rear Gear Package Kit:
4.56
4.88
4.88 with OE rear Locker
07+ Toyota Tundra Front & Rear Gear Package Kit:
4.88 w/ 5.7L
4.88 w/ 4.6L or 4.7L
If you need a quote, either EMAIL or CALL us: 866 525 4620
It is a common misconception that lower gears are only for hardcore off-roading, in actuality the average daily driven vehicle can see huge improvements in both performance and economy by properly matching their vehicle’s gear ratio to their tire size all while reducing strain on the vehicles drivetrain.
We at Nitro Gear & Axle realize how confusing and difficult it can be for the average consumer or gear installation shop to compile the list of gear parts and prices required when doing a complete front and rear gear change. To make it easier for everyone the experts at Nitro Gear & Axle are introducing an industry first - "Gear Packages"
These gear packages are specifically designed for many popular 4x4 applications such as the Dodge Ram, Chevy/GMC 2500/3500HD, Toyota Land Cruiser/FJ Cruiser/4-Runner/Tacoma/Tundra, Jeep Cherokee/Wrangler/Rubicon and Ford F250/F350 Super Duty.
These gears are manufactured from 8620 steel forgings and are precision machined using a computer controlled process. Heat treatment, CNC triple-lapping and Rockwell testing for hardness ensures excellent fitment, ideal contact pattern and smooth, quiet operation.
Nitro Gear & Axle sells ring and pinions for more than just the Dodge, Chevy/GMC, Toyota, Jeep and Ford vehicles listed in our gear package section so please contact us if you don't see your vehicle listed in our gear packages.
Bumping this back up! We have gears for many more axles then are listed under our Gear Packages. If you can't find what you're looking for online, send us an email or give us a call.
Congratulations to Jessi Combs and Nicole Pitell-Vaughan for successfully completing the Rallye Aïcha des Gazelles in their Total Chaos Fabrication Inc. built Tacoma. This truck is running NITRO gears among many other upgrades. We would also like to congratulate our friends Ronda Rhonda Cahill & Rachelle Croft of Expedition Overland on also completing the challenge.
If you are looking of the strongest ring and pinions to stand up to all the abuse you put your rig through, check out NITRO Gears!
We keep our gear package kits in stock and ready to ship out to you! If you have any questions let us know. If you don't see the options you are looking for, give us a call at 866 349 6801 or email us info@justdifferentials.com. Check out all our gear package kits online:
Looking to gain back some lost power, MPG, or acceleration after a lift kit and larger tires? Deeper gears are the answer. Give us a call at 866 349 6801 or email us at info@justdifferentials.com
Overlanding.
I don't need to regear, my tires are only a little bigger than stock.
It's a common statement and one we enjoy addressing when the opportunity presents itself. Overland preparation tends to add weight to the base vehicle. Bumpers, winches, skidplates and tire carriers can add a tremendous amount of weight from stock. Add a rooftop tent or rack assembly up high and aerodynamic drag is greatly increased as well further reducing performance both on and off-road.
Beyond increased weight, vehicle manufacturers almost always opt for a borderline gear ratio from the factory to optimize unloaded fuel economy. This means that even running near stock size tires, a heavily loaded, taller than stock and factory undergeared Overland 4x4 is a very poor performing machine both in terms of acceleration and fuel economy. This reduces cross country fuel range, on road responsiveness and off-road control all at the same time.
The solution is regearing. Proper gear ratios put the engine at optimum RPM for performance and fuel economy and give you the opportunity to add traction aiding differentials during gear installation greatly enhancing the capability of your backcountry 4x4 in the field, on the highway and around town.
Just Differentials is the leader with gear packages available for all the common Overlanding platforms. These kits include ring and pinions, full master setup parts and everything your mechanic needs to regear your rig and make it function as it should instead of gasping every time you climb a mild grade.
Call us at 866-349-6801 or check out our package options here.
One of our customers sent us some pictures of his very cool 2000 Toyota Tacoma long travel build featuring some great aftermarket parts including Nitro Gears and ARB Air Lockers front and rear.
We keep gears, install kits, lockers, axles and tons of other small parts in stock all the time for many different makes and models. Give us a call at 866 349 6801 or email us at info@justdifferentials.com for a quote today!
Diesel owners rejoice, Nitro now offers a 4.30 ratio for 2000 & newer AAM 11.5" rear axles!
Our brand new 11.8" AAM 4.30 gears are what every diesel owner has been waiting for. These new gears fit both the new AAM 11.8" housing and the 2000-2012 AAM 11.5" housings. Anyone with an older model 11.5" who has been waiting for gears can install this upgrade with ease. Larger diameter ring adds extra strength to your rear differential! Upgrade you GM or Dodge 2500 or 3500 diesel today.
AAM 11.8" Differential Gears
2001-2010, GM 2500 or 3500 - GPDURAMAX-4.30
GMC Sierra & Chevrolet Silverado with Duramax
Use AAM11.8-430-NG gear with MKAAM11.5 Master Kit
2011 & Newer, GM 2500 or 3500 - GPDURAMAX2-4.30
GMC Sierra & Chevrolet Silverado with Duramax Diesel
2003-2013 Dodge 2500 or 3500 - GPRAM-4.30
Dodge Ram with Cummins Diesel
2014 & Newer, Dodge 2500 or 3500 - GPRAM2500-4.30
Use AAM11.8-430-NG gear with MKAAM11.8-B Master Kit
The aftermarket is flooded with cheap low quality noisy and hard to set up gears that don't last when worked hard. At Just Differentials we stock brands that we believe in and hold up to what our customers put them through on the trail, race track or towing a trailer.
JustDifferentials.com for all your gear and axle needs.
We've been putting this LX470 together in the shop over the last few days. Recently we went through the suspension and axles, and added a Nitro Gear Package. Now we are adding Slee Off-Road bumpers, sliders and a Engo winch. If you are in the PNW and need a quote for some work on your vehicle let us know!
All our Gear Package Kits are available online. You can email us at info@justdifferentials.com or call us at 866 349 6801 for a parts quote.
Building a sweet 9 inch assembly in the shop this week. Nitro Nodular housing, Nitro LSD unit, Nitro 1350 forged yoke and a REM treated 3.50 Nitro Gear Set. REM treating produces an incredibly smooth surface finish for reduced noise, cooler running and longer lasting gears. Ideal for keeping gear noise to a minimum and an option on some Nitro gearsets.
We can build one for you as well, or just about anything else for your axles. Call 866-349-6801 or click on the link below to see all our gear and axle options:
Nitro Gears at JustDifferentials.com
