Nitro Gear - New lower price on the best aftermarket gears for your Tundra!
The only aftermarket gears proven by Toyota / TRD in their class winning Baja Race Trucks
2000-2006 Tundra Nitro Gear Package Kits
2007+ Tundra Nitro Gear Package Kits
The Nitro Gear 4.88’s for Toyota Tundra have been overwhelmingly popular. Due to the increased volume we’ve been able to do larger production runs and pass our savings on to you. Nitro gears are the most proven aftermarket gears for your late model Toyota. Our test vehicle has been using the 1st production set for several years. Even Toyota & TRD use Nitro gears in their class winning Baja Tundra TRD Pro and Tacoma. Toyota wanted the Tundra to remain as close to stock as possible, but the engineers behind the build felt it was important enough to run the proper ratio, and trust Nitro Gear. See the below link and stats on the Toyota USA website:
TRD Pro Desert Race Truck Specs
2015 Toyota Tundra TRD Pro CrewMax 4x4 5.7L V8
Item - Manufacturer - Details
Front Shocks - Bilstein - TRD-tuned Black Hawk Bypass
Rear Shocks - Bilstein - TRD-tuned Black Hawk Bypass
Front Springs - Eibach - Coil
Rear Springs - Deaver - Leaf
Tires - BFG - 37” Baja T/A KR
Wheels - TRD - 17” forged
Brakes - Toyota - TRD performance brake pads
Tube Roll Cage - Herbst Smith Fabrication - 2” .120-wall chromoly
Oil Accumulator - Accu-Sump - 3-qt. capacity
TRD Pro Front Grille - Toyota - TRD Pro component
TRD Pro Embossed Bed - Toyota - TRD Pro component
TRD Shift Knob - Toyota - TRD component
Fuel Cell - Fuel Safe - Custom
Batteries - Optima - Bluetop
Race Seats (Qty. 3) - Mastercraft - 3G
Seat Harnesses & Window Nets - Mastercraft
Front Lights - Hella - HID
A-Pillar Lights - Hella - LED Rallye 4000
Intake - TRD - Custom Cold Air
Exhaust- TRD - Custom Cat-back Exhaust
Control Arms - Toyota - OEM Component
Uprights - Toyota - OEM Component
Tie Rods - Toyota - OEM Component
Wheel Bearings - Toyota - OEM Component
Hubs - Toyota - OEM Component
Driver GPS/Nav - Lowrance - 6”
Navigator GPS/Nav - Lowrance - 10”
Race Radio - Kenwood - TK-790H 110 Watts
Intercom - PCI - Comlink 10 Elite
Gears - Nitro Gears - 4.88:1 Ring & Pinion
XtraCab
04-12-2020 06:25 AM
09-04-2015 10:27 AM
mengquis
07-13-2015 11:39 AM
Suprarossa
07-06-2015 06:21 AM
