Nitro Gear & Axle Master Install Kits
Nitro Gear and Axle Master Install Kits
Whether you are installing new gears, or just overhauling your axles, you can count on Nitro Gear and Axle to have all the parts to help you get the job done right the first time. In addition to the Master Install Kits listed below, we also carry Mini Install Kits, Gear Packages, Ring and Pinions, Differential Covers, Differentials, and anything else you need for your axles.
The kits assembled by Nitro Gear & Axle only uses the highest quality bearings available from Timken & Koyo. Nitro Gear & Axle does not use any cheap Chinese bearings. By using only Timken & Koyo bearings just like all of the OEM vehicle manufacturers you can be assured that your differential will be reliable, durable, & quiet for years to come.
We offer multiple different types of install kits, check them all out below:
Carrier Bearing Kit
Master Install Kit
Pinion Bearing Kit
Bearing Kit Only
Knuckle Kit
Mini Install Kit
Transfer Case Kits
Carrier Bearing Kit
Master Install Kit
Pinion Bearing Kit
Bearing Kit Only
Knuckle Kit
Mini Install Kit
Transfer Case Kits
Take a look at our newest master install kit, built to suit the GM 7.625” IFS front used in Hummer H3, Chevy Colorado, GMC Canyon, & Isuzu Ascender. It includes the proper triple lip pinion seal, 4 stub axle bearings, & 2 stub axle seals.
jerusry
10-19-2015 06:28 PM
09-04-2015 10:27 AM
