NITRO Chromoly Birfield shafts form Just Differentials!
NITRO CHROMOLY Birfields & Axles - Now available for Toyota applications!
Toyota Trucks & Landcruisers are well known for their strength & reliability all over the world. Out of the box they feature some pretty great drivetrain, but they do have their limits. The factory axles are 30 spline at the diff, but neck down to 27 spline at the birfield creating a failure point. Additionally the factory Birfield joints are not built to withstand the added stress of larger tires and heavy off road use. Nitro Gear & Axle has addressed this by offering a range of Heavy Duty Chromoly Birfield Joints & Axle Shafts.
-NITRO 30/30 Kits feature axles that have 30 splines at both ends, eliminating the factory neck-down. Fully compatible with factory or aftermarket carriers, lockers, & hubs.
-High strength Chromoly Material featuring State of the art machining, heat-treating and polishing processes for uniformity and ultimate in strength.
-Wide application range suiting most Toyota pickups, 4runners & Land Cruisers
Complete Chromoly 30/30 Birfield & Axle Kits (BOTH SIDES) Applications (All kits include inner axles that have 30 splines at both ends, birfield joints for both sides) FJ80 KIT IS 30/BIG24:
AX TBIRF-30-KIT 79-85 HILUX & 4RUNNER W/SOLID AXLE 30/30 SPLINE
AX TBIRF-FJ40KIT 76 & UP LANDCRUISER FJ40 & BJ70 30/30 SPLINE
AX TBIRF-LJ70KIT LANDCRUISER II, LJ70, RJ70, BUNDERA, 30/30 SPLINE
AX TBIRF-FJ60KIT 81-90 LANDCRUISER FJ60/62 30/30 SPLINE
AX TBIRF-FJ80KIT 91-97 LANDCRUISER FJ80, FZJ80 (USES 95+ DRIVE FLANGES)
Individual Birfield joints: (Featuring replacement spline configuration to fit stock joints/axles)
AX TBIRF PICKUP, 4RUNNER, LANDCRUISER FJ40/55/60/62, LJ70 27 SPL (STD JOINT)
AX TBIRF-4340 PICKUP, 4RUNNER, LANDCRUISER FJ40/55/60/62, LJ70 27 SPL (HD JOINT)
AX TBIRF-FJ80 91-97 LANDCRUISER FJ80, FZJ80 (REPLACEMENT JOINT)
AX TBIRF-FJ80HD 91-97 LANDCRUISER FJ80, FZJ80 (CHROMOLY/300M HD JOINT)
Individual Axles, Rear Axles, Drive Flanges, Knuckle overhaul kits, wheel bearings and more are also available!
A lot of that depends on what size tire you are running, how much power you intend to make after the motor is swapped in (are you going to tune it at all?), and your driving style.
If you want, give us a call and we can talk to you about your options: 509 888 2953.
I also have a question; so these shafts let you leave the front ifs and just eliminate the cv joint? Are these knuckle things stronger than cv joints and or do you guys have a U-joint front ifs conversion? Are they bolt on? -Dan
They are bolt on shafts, they eliminate the stock cv joint and shaft and use a much stronger birfield joint and chromoly shaft. If you need some pricing on them let me know.
Bumping this back up! If you need a quote you can always get a hold of us using the contact section of our new website:
hiluxinargentina
10-01-2015 12:12 AM
hiluxinargentina
09-30-2015 06:51 PM
