Nitro Big Pinion Conversion Kit for Dana 44!
Old 07-26-2013 | 05:26 PM
justdifferentials's Avatar
The Nitro Big Pinion conversion kit for the Dana 44 is a significant increase in strength for your traditional type Dana 44 axle by allowing the fitment of the later “New Generation” type gears that are used in late model Jeep Wrangler JK rear axles.
I know most of you aren't running a Dana 44, but we have run into a fair amount of Toyota guys who have swapped them in over near us.
Larger 24 spline Pinion shaft which measures 1.25” vs. standard 26 spline shaft which measures 1.11”
Larger 8.875” diameter ring gear vs. Standard 8.5” ring gear
Fits: “3 Series” 3.73 & down carrier or aftermarket locker
Nitro Dana 44 "Big Pinion Conversion Kit" Includes:
- Ring & Pinion - larger and stronger than the standard ring & pinions
- PK conversion kit (Pinion Bearings, Seal, Nut, solid spacer, shims, bearing spacer, R/G Bolts)
- Pinion yoke in 1310 or 1350 series
Nitro Dana 44 "Big Pinion Conversion Kit" part numbers:
D44-373BP-T-NG - Dana 44 - 3.73 Ratio Big Pinion Conversion Kit
D44-411BP-T-NG - Dana 44 - 4.11 Ratio Big Pinion Conversion Kit
D44-456BP-T-NG - Dana 44 - 4.56 Ratio Big Pinion Conversion Kit
D44-488BP-T-NG - Dana 44 - 4.88 Ratio Big Pinion Conversion Kit
D44-513BP-T-NG - Dana 44 - 5.13 Ratio Big Pinion Conversion Kit
D44-538BP-T-NG - Dana 44 - 5.38 Ratio Big Pinion Conversion Kit
Old 08-05-2013 | 03:36 PM
Nitro Dana 44 "Big Pinion Conversion Kit" part numbers and links:
PNWrider
10-30-2015 09:14 AM
justdifferentials
Just Differentials
08-15-2015 06:25 PM
kirkrunner
07-27-2015 08:59 PM
justdifferentials
Just Differentials
07-22-2015 09:26 PM
crashburnoveride
07-10-2015 07:39 AM
