Cut To Length (CTL) Axles - Just Differentials
Old 12-06-2014 | 12:44 PM
justdifferentials's Avatar
Nitro Gear & Axle now offers an assortment of Heavy Duty Cut-to-Length (CTL) rear axle shafts. The CTL axle shafts feature extra long splines and can easily be cut to the desired length with a chop saw. This allows Nitro to use stronger rolled splines rather than cut splines and allows fewer part numbers to cover a wide range of OE and custom applications. This also makes it easier for Offroad, restoration, and Rod Shops to stock axles since they fit so many applications.
AX D44-35-CTL 35 SPLINE CTL AXLE SHAFT, DANA 44 & 60
AX D44-30-CTL 30 SPLINE CTL AXLE SHAFT, DANA 44 & 60
AX F9-35-CTL 35 SPLINE CTL AXLE SHAFT, FORD 9”
-HIGH STRENGTH 4130 HEAT TREATED CHROMOLY WITH ROLLED SPLINES
-TRIM TO DESIRED LENGTH FROM 24.5-34"
-TRIPLE DRILLED WHEEL PATTERN INCLUDES 5X4.5”, 5X5”, 5X5.5”
-ACCEPTS JEEP JK ABS RINGS.
-USE WITH AFTERMARKET LOCKER TO UPGRADE MANY APPLICATIONS, JEEP CJ, YJ, TJ, XJ, MJ, ZJ, JK, IHC SCOUT, LARGE BEARING FORD 9”, SEMI FLOAT DANA 60, CUSTOM APPLICATIONS AND MORE
-NO NEED FOR CUSTOM AXLES!
To see all the available axles go here: Just Differentials - CTL Axles
Wholesale Programs Available through:
JTS Parts & Accessories / JTs Parts & Accessories, Justdifferentials.com info@justdifferentials.com 509-888-AXLE (2953) 866-399-7532 fax
jerusry
10-19-2015 06:28 PM
ripp96
07-31-2015 12:14 PM
Athansinis
07-27-2015 09:38 AM
justdifferentials
Just Differentials
07-22-2015 09:26 PM
Nickdigg
07-07-2015 07:04 AM
