Toyota Engine Mounts, bolt in or weld in sets!
Over time the rubber of a Toyota truck stock engine mount becomes weak and brittle. Combine this with the heavy torque loads produced by your engine and transfer case when off-roading and your stock mount will fail. To eliminate this problem 4x I. engineered this beautiful creation.
From the bottom up it was clear a small bushing just wouldn’t do, so a monster 2-inch Energy Suspension round bushing was selected to dampen engine vibrations. In order to squeeze this bushing between things like radiator hoses, your alternator, A/C pump, and more a whole new bracket had to be engineered. Over a year in the making the new brackets replace everything between your stock frame and engine block. Kits are currently available as complete bolt-in sets.
Super-Duty Engine Mounts are available for any truck with a 22R series (22R, 22R-E, 22R-ET) engine for $163 ready to bolt in.
voiddweller
19
05-02-2016 10:10 PM
JaredL
06-16-2015 05:47 PM
