New Wheel Hub & Unit Bearing Assemblies
We are now pressing together and pre-assembling KOYO Unit Bearings with Toyota Spindles for Type 3 & 4 4WD IFS Knuckles!
This is everything you need to replace your wheel hub parts in an easy-to-install pre-assembled Japanese-made long lasting and high performance unit that does not require a press or special tools to install!
Pre-assembled parts:
Click for details: marlincrawler.com/product/pre-assembled-wheel-hub-unit-bearing-type-3-type-4
- Toyota/KOYO Front Unit Bearing
- Toyota Spindle
- Toyota Outer Seal for Hub to Bearing, greased & installed
- Toyota Mounting Bolts (4), installed
- Toyota O-Ring for Unit bearing to Knuckle
- Toyota Cotter pin for CV Axle Nut
kevincook
18
12-22-2012 06:50 AM
