Toyota Gears and lockers
Old 12-09-2011 | 10:39 AM
  #161
ScottyC's Avatar
DEEP discounts on the website on these for Xmas right now!
Old 12-09-2011 | 11:02 AM
  #162
4runninmuds's Avatar
I'm looking for some front and rear 4.88s. 94 runner, 22re, 5spd. Does Aussie make a locker for the rear 4.88?(JW) I see Aussie wasn't one of your options up top.
Cheers
Old 12-12-2011 | 10:16 PM
  #163
Anybody therrrr???
Old 12-12-2011 | 10:21 PM
  #164
89silverpu's Avatar
Originally Posted by 4runninmuds
Anybody therrrr???
http://www.aussielocker.com/index.ph...-xd-24930.html
Old 12-12-2011 | 11:25 PM
  #165
Thanks
Old 12-13-2011 | 04:35 AM
  #166
ScottyC's Avatar
Cheers
Sorry, I'm not always able to get to my pms as fast anymore. Its much easier to call me for a quote.
But, I am sending you a PM now.
Old 12-16-2011 | 08:30 AM
  #167
ScottyC's Avatar
ttttt
Old 12-20-2011 | 06:39 AM
  #168
ScottyC's Avatar
10% off sale for website orders!
Old 12-23-2011 | 06:50 AM
  #169
ScottyC's Avatar
Sales Ends 12/31
Old 01-06-2012 | 06:03 AM
  #170
ScottyC's Avatar
ttttt
Old 05-19-2012 | 08:23 AM
  #171
ScottyC's Avatar
Originally Posted by windwalker
Iam looking for spider and side gears for a Toyota T100 4X4 base modle
I have a full open carrier from a 8.4 at the shop I could sell. $50 + shipping. Call me Monday if you need it. 970-420-4198
scotty
Old 05-21-2012 | 05:39 PM
  #172
jonwaynester's Avatar
I just got new axle gears. I was wondering if when i get them installed in my rear 3rd member which is currently welded, if i will strip my new gear set? I have heard that i will be ok? what do u think?
Old 05-21-2012 | 06:30 PM
  #173
windwalker's Avatar
PM sent
Old 05-23-2012 | 10:30 AM
  #174
I just got new axle gears. I was wondering if when i get them installed in my rear 3rd member which is currently welded, if i will strip my new gear set when i take corners? I have heard that i will be ok? what do u think?
I posted this same question a few days ago and no one has helped me. Iam sure someone out their can help me.
__________________
Old 05-30-2012 | 06:14 AM
  #175
ScottyC's Avatar
__________________
We don't ever recommend welded diffs, but the gears should be fine to swap out.
Old 05-30-2012 | 08:18 PM
  #176
Thanks for your response scotty ;-) I figure that my new gear set would be ok, i just wanted to make sure just cuz this will be my 1st time putting lower axle gears. I would install a better locker but i cant afford it seeing that lockers are anywhere from 900 to 1200 bucks. mabey someday! my new gear set is 5.29s i hope all goes well!
Old 05-31-2012 | 07:39 AM
  #177
ScottyC's Avatar
$900-$1200????
Only ARBs are that much. Spartans, Lockrights, Yukon Grizzly Locker, etc are MUCH cheaper than that. IN fact, you would be better off running a spool for $149.
Just my $.02
Also, if you have never set up gear before, then make sure you have the proper tools to do it. Toyota gears are EXTREMELY sensitive to proper setup and should be left to those guys who have a lot of experience doing them. They are not for a first timer.
Old 05-31-2012 | 02:33 PM
  #178
I really do appreciate your help. I think i will do a spool.
I have heard that a welded locker has its pros and cons. I have been welded for 4 years and i have 35s and have not had a problem. I guess its just my luck.
O for sure iam having my new gears installed by a professional that knows what he is doing
Old 06-18-2012 | 05:13 PM
  #179
94_yota_4x4's Avatar
how hard is it to set the toyota gears? i have a good bit of experence in setting gears most on ford 8.8 but are the toyota gears really that much different?
6th Gear
19
12-10-2019 07:31 AM
YotaLogic
12
11-17-2015 06:27 AM
merc1100sc
06-26-2015 05:24 PM
ACZR
06-23-2015 07:55 PM
AustinTaco
06-21-2015 09:54 AM
Quick Reply: Toyota Gears and lockers
