habanero's 1996 4Runner Build-Up Thread
Old 08-21-2023, 07:51 PM
  #4521
Kevog80's Avatar
Originally Posted by habanero
Do you have the thread link and post number so I can go back and review? I see the rear heater hose in the pic, there's a few vacuum lines and a connector back there, among other things
Try posts 3721 (hoses on the back of the intake manifold) and maybe 3724, see if those make sense.
https://www.yotatech.com/forums/f200.../index187.html
If that's not what you're looking for I'll look a little harder at the engine tomorrow afternoon- it's dark now. You're correct, mine is a 96 sr5 4x.
also here is the pic of my engine w the port I need help with
Old 08-21-2023, 08:04 PM
  #4522
Kevog80's Avatar
I believe it's a connector port and it does have suction when u put your finger on it, and what's weird is when I look at some pics online of the 3.4 the port isn't there, so maybe it wasn't used for certain year models..Thanks for your help.
Old 08-22-2023, 02:56 AM
  #4523
habanero's Avatar
It's still dark now, I'll peek under the hood this morning when I let the dogs out. With those pics I can see exactly what you're looking for and where it's at.
If you look at post #3 on the link you posted, 3rd picture down there is an apparatus, looks like a vsv, with a vacuum hose and a breather- my 96 doesn't have one of those.
Could yours be plenum port to vsv (bottom arrow), with a second vac line (top arrow)?
That bears some looking into...
You've piqued my curiosity, I'd love to know the answer.
Old 08-22-2023, 03:45 AM
  #4524
habanero's Avatar
Okay, try this https://toyota-usa.epc-data.com/t100...ine/1708/?full
The site is usually slow to load. It's a vacuum diagram for a 96 T100 3.4 engine...I don't think you'll find one of these particular vsv's on a 3.4 4Runner, but I don't know that as fact.
Old 08-22-2023, 05:16 AM
  #4525
Kevog80's Avatar
that could be a possibility I don't recall seeing that sensor apparatus w the 2 yellow arrows. Thing is that makes it so weird , nobody seems to know either as of yet it has stumped me. I don't see any hoses around and only reason I reached out to u is, that post u replied to is the only engine I've yet to see w that same port, but it has a factory cap on it. I really am considering putting a cap on it, but would love to know the purpose bc I may need it? I took all the plenums and rail back off just to search for hoses. I'll send this pic of another motor of the area but there is no port in that same area, it's so strange. Here is a google image of the exact same area and look no port but if it helps others to see more of the area that I'm talkn about.
Old 08-22-2023, 05:23 AM
  #4526
Kevog80's Avatar
here is the vacuum diagram under my hood even the diagram doesn't show the port or a hose
here is a picture from under my hood of the vacuum system diagram even this shows no hose leading to that port
Old 08-22-2023, 05:29 AM
  #4527
Kevog80's Avatar
and sorry to blow you up with all these pictures, here is exact picture of the bottom of my Plenum. The connector is bottom left corner that I'm looking for, to the right is where it bolts to firewall wiring harness
Old 08-22-2023, 01:44 PM
  #4528
habanero's Avatar
Pictures help so no worries.
Did you look at the vacuum diagram for the 96 T100 that I posted the link to? The port is shown in the diagram along with the vsv also pictured above with the yellow arrow pointing it out.
It's simply for a truck like the 96 t100 etc. with a 3.4 that makes use of the vsv there, Toyota used the 3.4 before the 4Runner.
I don't know exactly what for, something that uses vacuum switching valves that we don't have at that particular spot.
My 96 was built 12/95, there are a few older tech leftovers on it that even some of the newer 96s don't have and this seems to be one.
Cap it, there shouldn't be anything you need it for.
Old 08-22-2023, 03:11 PM
  #4529
Kevog80's Avatar
OK I finally was able to get the diagram that u sent & I believe u are absolutely correct. Maybe it was some EGR/VSV stuff. Bc mine was build 11/95 and mine even has the 2 capped hose ports on the throttle body that aren't used in newer models but was used in some older models. I believe it was prob originally capped and the cap was lost or something. I really appreciate it dude bc honestly that's the ONLY diagram I have seen that shows that port. This has been driving me nuts for quite a while now and looks like it's finally over haha. Either way thanks so much and last question, do u know what the factory port cap oem number is or do they even sell them?
Old 08-22-2023, 04:36 PM
  #4530
Kevog80's Avatar
actually found them if anyone needs some here us part num 90339-03002
thanks again man
The following users liked this post:
habanero (08-22-2023)
Old 08-22-2023, 06:34 PM
  #4531
habanero's Avatar
thanks again man
Not man, ma'am
I do like a puzzle, glad to have helped sort it out. Thanks for sharing the part number for the cap.
The following 2 users liked this post by habanero:
coopster (08-23-2023), octanejunkie (11-08-2023)
Old 08-23-2023, 07:39 AM
  #4532
coopster's Avatar
Location: exo-reality -wave if you see me; Front Range, CO
I (am) putting a 99 3.4 into my 2nd gen (interesting it was made in 10 of 95). This plenum does NOT have that port.
Old 08-23-2023, 08:55 AM
  #4533
Kevog80's Avatar
Is strange but the 3.4 was used in several Toyota models maybe I had a leftover t100 engine
Old 08-23-2023, 08:56 AM
  #4534
Kevog80's Avatar
Not man, ma'am
Oh Geeze im sorry rookie mistake. But glad the puzzle is figured out
Old 08-23-2023, 09:14 AM
  #4535
Kevog80's Avatar
actually really cool seeing females know their engines . I usually watch Faye Hadley on YouTube she has saved my ass many times
Old 08-23-2023, 01:33 PM
  #4536
habanero's Avatar
I'll bet Faye's way better versed in all things engine, will have to check her channel out. I just like to tinker with tools and figure things out.
Old 08-23-2023, 02:28 PM
  #4537
Kevog80's Avatar
yeah me too since last time I let a dealership change valve covers timing belt and bad knock sensors between parts and labor it was $3600. So I try to do my own labor if possible, dealerships screw ppl wayy too much
Old 08-23-2023, 04:17 PM
  #4538
habanero's Avatar
Whoa! Makes me glad I've been able to do those things and put those dollars to new tools and the fun and games parts of the build.
Old 09-08-2023, 03:22 PM
  #4539
habanero's Avatar
96 4Runner 329,190 miles
Replaced the power steering filter today. Of course I took the old one apart. It's got some gritty junk in the paper and the magnet, nothing too scary and a whole lot less than the last one.
I'd last replaced it Jun 2017 with 290,xxx miles.
Have an appointment for an alignment on the 27th, driving it only a little bit until that gets done.
old87yota (09-11-2023)
Old 11-07-2023, 04:06 PM
  #4540
habanero's Avatar
96 4Runner 329,xxx miles
Did a weird little thing...
Tool from Grandpa's toolbox
Altered a little bit...
Hose clamped to the winch freespool lever, a hole added to the bumper, a 3/8-1/2 adapter and...
more to do, but so far so good
chuckles89 (11-10-2023), octanejunkie (11-08-2023)
Quick Reply: habanero's 1996 4Runner Build-Up Thread
