Addicted Offroad's 2000 4Runner Build-Up Thread "Intervention"
Old 04-29-2010, 05:20 PM
  #241
ScottyC's Avatar
Welded the link brackets on the axle today.
Old 04-29-2010, 07:35 PM
  #242
dannomite's Avatar
pshhhh those welds look like crap. Just kidding. This is my favorite build in all of Yotatechland. Kudos. Huzah.
Old 04-30-2010, 02:50 PM
  #243
ScottyC's Avatar
T100 oil pan went on today.
Then I moved the front axle forward 1.75" and tested clearance with a tire installed. Its good by around an inch at the firewall and inner fenders. No issues there, but the front is going to require some trimming.
Old 04-30-2010, 07:08 PM
  #244
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
nice dude... still jealous hahaha
ok, so, as my post count shows, I'm not a newb around here, and I don't typically highjack, but I do have one quick question that I don't want to start a thread over.
I am replacing my entire rear axle with another on my 3rd gen. Do I need to use coil compressors to achieve this? I'm thinking def, but my buddy said not, soo, I dunno haha, I was hoping you would know.
and when I win the lottery, I am buying it, I got dibs
Old 04-30-2010, 07:33 PM
  #245
ScottyC's Avatar
You won't need them at all. Just undo the sway bar, shocks, and have someone step on the brake while you slide each spring into place. Piece of cake.
Old 04-30-2010, 07:37 PM
  #246
Thanks Scotty, sorry for the hijack lol
Old 05-01-2010, 06:34 AM
  #247
waskillywabbit's Avatar
Wish you were closer, I'd love to come see it.
Old 05-01-2010, 07:11 AM
  #248
ScottyC's Avatar
me too! I would ask you to help!
Old 05-02-2010, 08:03 PM
  #249
LIVES4CRAWLIN91's Avatar
Love it Scotty, and if i won the lottery I'd come drop mine off and say here "hands u a list" have fun... cuz id hate to split u from ur no expense spared build and just have one of my own
Old 05-03-2010, 11:05 AM
  #250
ScottyC's Avatar
Well, I finally got the new coupler into the prerunner adapter. I tested it and sure enough the input was bottoming out on the small flange/neck inside the Inchworm coupler. This was keeping the mounting surfaces from sitting flush by about 1/4". However, the Marlin one sliders another 3/8" onto the crawl box input shaft. It allows both surfaces to sit flush.
Here are some pics. First one is the Inchworm coupler. 2nd one is the Marlin coupler.
Also, just as a reference. The crawl box is a Trail-Gear crawl box with their 23 spline 2.28 input. So, that input will work with the Marlin coupler as it just sliders right on it. I have heard that the 4.7 gear will not though. I have one here and it looks like it could be pressed, but I doubt you could do it considering you still need to POUND the Marlin coupler onto the transmission output anyway.
Old 05-04-2010, 03:59 PM
  #251
ill def keep that in mind on my coupler ordering ...
Old 05-14-2010, 05:07 PM
  #252
ScottyC's Avatar
So, I haven't done much. Been waiting on some stuff to come in, and needed to rethink A LOT. I ended up ordering some coilover towers, but they just are not going to work. If I was going full hydro they would be sweet, but oh well.
So, today I welded the knuckle balls in place on the axle. Set at 4* of caster.
I also bent out what I hope will work for some coilover hoops. I also mocked up where the steering box is going to go, although it still needs to move up at least an inch.
Panhard bracket mocked up. I have checked this with the coilover location and it should clear throughout the cycle. I will check it more before finish welding everything.
Reamer for GM 1ton rod ends.
TRE size difference between the GM 1 ton ends and the FJ80 ends.
Old 05-14-2010, 06:27 PM
  #253
StangBanger's Avatar
whoa..Nice..
Old 05-14-2010, 11:39 PM
  #254
paynemw's Avatar
dude scotty, i become more and more amazed with every thread you post... i just finished reading your bio up on AOR.... mad jealous, do work sir
Old 05-16-2010, 07:22 AM
  #255
ScottyC's Avatar
Thanks!
I am very blessed in the fact that I get to do what "I want to do" everyday as opposed what "I have to do".
Old 05-17-2010, 06:39 PM
  #256
And at the end of the day..Thats what counts..Congrats man..
Old 05-20-2010, 04:29 PM
  #257
ScottyC's Avatar
Got a lot done today. I have no rigs in the shop getting work right now for the next four days, so I am going to knock as much stuff out as possible.
Steering box is in. Tie-rod is cut and welded. Draglink is next. Panhard is cut and welded.
Only thing I am going to have to change is to raise up the frame side panhard mount another inch and a half to 28". Its too low and its currently the only clearance issue I have at this point.
Old 05-27-2010, 03:42 PM
  #258
ScottyC's Avatar
So, its sitting on the coilovers.
Going to need to go with triple rates and 10" uppers to get the ride height down and to keep the coils from flopping around at full droop. Its taller than I wanted which is why I want to switch. It needs to drop 1.75" from where its at. I have 6.75" of shaft showing. I know it will settle in with a bumper and winch as well though too.
Old 05-27-2010, 04:20 PM
  #259
dannomite's Avatar
Unreal!
Old 05-27-2010, 06:38 PM
  #260
space-junk's Avatar
sooo, your making this for me as a birthday present, riiiiggghhhhttt???
absolutely GORGEOUS work you do, Scotty... wish i lived closer so i could come harass you during the day and watch you work...
Quick Reply: Addicted Offroad's 2000 4Runner Build-Up Thread "Intervention"
