Yikes! VSC Off light, VSC Trac light and Check Engine light all at once.
Driving along at 55 miles per hour and all of a sudden, the VSC OFF light, the VSC TRAC light and the CHECK ENGINE light all come on at the same instance. Truck seems to be running fine. Any ideas on what I have going on before I dive into this myself to try and diagnose??? 2001 4 Runner, 4x4 w/ lockable center diff. THANKS
Thanks for the feedback. I had a scan done and it came back with a P1135 Code - Manufacturter Fuel Air Metering. I will check gas cap. Can anyone translate that code into plain engish for me?? Thanks
"Air/Fuel Ratio meter heater circuit malfunction, Bank1 Sensor1".
Basically your front (pre-cat) Air/Fuel ratio meter has started acting up. They are costly ($200 to $300). Mine did this for a couple of months and I just drove around with my OBD tool plugged in all the time to keep resetting the code. Finally replaced the sensor and all is good.
06-01-2021 01:51 PM
