which years had the spare on the tailgate ?
im looking into buying a 4runner , and would like the one wit hthe spare on the tailgate , what years were they ? and i assume they had the v-6 then also .
airrikk17
airrikk17
airrikk17
airrikk17
I've got one on my 94, but of course it came off of a 91. I've seen them on 90, 91 and early 92's. Saw a early 92 at the yard and it had a swing arm tire carrier and underneath all the hardware for a spare (Can you say duel spares) as if they don't sag enough in the rear already.
Spare tire carrier
Having owned 2 previous 2nd gen...the only years i know of from owning them were from 90-91...perhaps in the US they extended it to 92 or 93...PS: I have been contemplating adding the 2nd gen tire carrier to a 3rd gen limited...i like to idea of an accessible tire quickly, do you know if anyone has ever tried this modification?
Used to be a writeup on the ORC Toyota tech section:
http://www.off-road.com/toyota/toyota.html
Was written by Chris Geiger. Basically you need to weld in a bunch of bracing inside the rear corners to install the carrier.
With the help of a buddy we chopped some metal strips up and they were used as the inner bracings with equally HD hardware. Not a problem in the past year its been installed. Been tested through some very rough terrain and looks great. Stock only used tin bracing on the inside tac welded on. scary.
DrZero
18
07-24-2015 11:31 PM
MTLroadierunner
07-20-2015 03:07 PM
lfcarrion3
07-18-2015 04:05 PM
sabine
07-18-2015 03:59 PM
