would this help bring my back end up?
MR GASKET RUBBER COIL SPRING SPACER, FRONT -- 1'' Lift, 4'' Inside Diameter, 6'' Outside Diameter, An Ideal Way To Raise All Coil Spring Equipped Cars Without Affecting Handling Or Ride, Features U Shaped Section, Fits Above Or Below Coil, Requires Spring Removal To Install, With Manufacturer's Limited 90-Day Warranty"
or where can i buy new replacement springs
thanks for youe help
o ya and if this will help i can aford them
Pro Comp Rear Leaf Spring
1984-1998 Toyota 4Runner"PRO COMP ADD-A-LEAF KIT, REAR, SHORT -- 1.5" - 2.5" Lift, Helps Renew The Height And Strength Of A Rear Spring Suffering From Fatigue, Strengthens The Integrity Of An Existing Leaf Spring Pack, Includes Two Single Leafs And New Centering Bolts, With Pro Comp's Limited Lifetime Warranty
What kind of vehicle do you have? That would be really important seeing as you are looking at parts first for something with a coil spring rear suspension and then something with leaf spring rear suspension. I have never heard of the Mr. Gasket stuff, and if your vehicle has rear leaf spring suspension, then you should be ok with the AALS
MOD EDIT: (Lysmachia) BANNED!
X-TOOL posted 60 bannable images. Way tooo much crap.... I coulda banned all posts but I wanted everyone to see what a jerk he was. 60 posts of the same Image... I hand cleaned this one.
Come on Guys! We ALL OWN YOTA's Who cares? Let's leave the fighting to the hummer guys!
ya i have a 1996 2wd 4runner and there more i think about it i want to lift it and turn it into a prerunner so would a toytec 3" 4Runner Lift Kit
Included in kit:
3" Front Lift Spacers-- CNC Machined From T-6 6061 Aluminum
6 longer top plate spacer studs
3" Rear Lift coil springs (2" lift rear coils also available-same price)
Install Directions
help it rather then buy new springs or spacers
Included in kit:
Install Directions
It will work... my lift was all spacer at first... just about 7-8 mo ago I finally replaced the rear with OME springs from someone on here, SO MUCH BETTER =)
Right now I have the springs, AND a 1" rubber spacer from AutoZone in the rear... for 3.5ish" lift total. The kit you just listed doesnt sound too bad
Just go with OME. Spacers would work but it really depends on the shape of your current coils. If they are sagging then your just putting a band aid where you need stitches. Look into the 881 / 906 combo. I know there are a few threads about them on here. I recently installed it and i am very pleased.
My 97 usta sag in the rear like my ex girlfriend.I had the daystar spacers installed and now she sits all level... I forget the size i had installed but i think that were 1.5? anyhow you cant go wrong with them.. inless you have other issues..
Coast your 4runner to the local stealership, Tell them that you want the coil spring re-call special!
*The rear springs are under re-call and you get a brand new set of rear springs for FREE!!!!
After that da sag be gone!
I took mine to the dealership and had the recall done.. it did not fix the sag. the only thing that fixed MY sag was the spacers.. I thought the recall was supposed to fix the sage too. but i was wrong..
Hey,
I guess you can say that i got a "lift" out of the install. I did noticed a firmer ride since i had them installed. I tow things Pop up trailer, jetski ,small bassboat Without the spacers it would sag and with the load it would even more.. I think it looks better, and i think it performs better with the spacers. I was not looking for a lift persay-But more for leveling purposes..
