WOT Signal Light?
why would you want it? i would say dont tap into anything for a signal light.... it may affect the reading.... however you might be able to rigg up a swich like a momentarty push switch onto the throttle body area and make it so when something opens up it will push on the switch and light a light....
i hope you are planning to be spending tons of money and using a fully rebuilt engine..... a 20 year old 22re isnt going to be able to handle nitrous without some damn good internals and probably about $10k in real engine building
think about it... its 20 years old, and forced induction without rebuilding is going to blow it......
no, its fine dont worry... hell run a 300 shot.....
I'm P****ED!
I'm P****ED!
you could use a micro switch on the throttle body and when the throttle is full open and the switch will be activated and your light will come on. plus you will wanna use this micro switch to activate your nitrous. like the other guy said on a 20 yr old motor and no rebuild, you will prob blow the motor really fast..
06-01-2021 02:51 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 09:05 AM
moonpie
08-01-2015 12:58 AM
PopsDad1
07-30-2015 03:21 PM
