Is this worth it ?
Is this worth it ?
I have a guy offering me the following ride for $7000. Do you think it is worth it ? I have an 05 Limited 4wd right now and just ran across this as a second ride.
http://norfolk.craigslist.org/cto/1240150670.html
Thank you in advance for any help. Going to go see it tomorrow. Is an SR5.
it's not running 5.88 gears, most likely 4.88's
probably running 02 headlights, 03 would be hard to put in there.
my guess its got 3" bl on it, which is the worst thing.
Said it was 1" body lift. Said they were 5.88. How could I check ? What should I look for tomorrow to make sure I am getting what I need ?
http://www.grimmjeeper.com/gears.html
use that to figure out the rpms for certain speeds, but remember your speedo will be off.
also with the 5speed 33's and 5.29s your going to be running 65ish at 3k rpm, it will drive like a semi.
IntoTheVoid
10-24-2015 04:54 PM
sonorn67
09-19-2015 05:39 PM
