will i drain the battery?
I am runnin a pair of hella 500 driving lights with the h3 100watt bulbs in them instead of the stock 55watt that comes with the set. My brother tells me I will drain my battery. I do not intend on turning the hellas on when the engine is off. how much can it take. I got it wired with a relay and a swith connected to the dash with 12 volt directly from battery.
I have 130 watt KC's and I can run the heated seats, headlights, stereo... all the accessories, and I can turn them on and I don't notice any dimming of and lights on the dash or anywhere.
I have a question to everyone. Should InFlames be concerned about the wiring? Maybe it has a smaller gauge and may melt? Or are they basically wired the same as a higher wattage model?
i have 3 hella 510s... they run differnt wattages but i have a total draw of 17.5 amp... 210 watts... no problems at all... and i routinely leave them on for about 20 minutes with the engine off without a problem.....
tazman1972
11
09-28-2015 11:32 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 04:30 PM
Boomer8404
09-17-2015 08:59 AM
