will a clutch purchased for a 3.0 fit the same for a 3.4?
Old 11-26-2012 | 08:02 PM
roysome's Avatar
i have searched and cannot find the answer directly. i bought a clutch kit and flywheel from marlin for my 91 3.0 but ended up selling it before i put it in an still have it lying around. i am wondering if it will work for my 99 taco that i just bought?
i was told by marlin that my 3.0 tranny would bolt up to a 3.4 but only with a new bell. so i would assume that the clutch would fit be need to make sure first. any advise will help
Old 11-27-2012 | 05:04 AM
akaphilly's Avatar
check both parts online. if they have the same part number then i assume it would work
Old 11-27-2012 | 07:09 AM
waskillywabbit's Avatar
Clutches fit the flywheel/motor, throwout bearing fits the tranny.
:wabbit2:
Old 11-30-2012 | 10:55 AM
roysome's Avatar
thanks!
Old 11-30-2012 | 01:22 PM
Pat8942's Avatar
Toyota Parts Catalog Shows Different Part Numbers For 3.0 And 3.4 Disc And Cover, so I would Guess No.
Old 11-30-2012 | 03:55 PM
jskijoe's Avatar
Your r150 will bolt up to the 3.4 because that's what have since I did the 3.4 swap. The clutch may not work with the 3.0 flywheel and vice versa but someone told me once that the heavier duty clutches that TRD used to sell for the 3.0 were just the 3.4 clutch and flywheel assemblies and designed to handle more power via surface area contact. Im sure someone on here can can confirm or shoot that down. My feeling is that it will work though...
toyotamonster
3.4 Swaps
7
04-16-2020 07:02 PM
XtraCab
04-12-2020 06:25 AM
jasonty
41
12-23-2018 02:00 PM
Amer
3.4 Swaps
19
06-05-2017 11:43 AM
BeMiceElf
10-10-2015 10:40 PM
