Will A 1997 Tacoma Strut And Spring Assembly Bolt Into My 1997 4runner?
Will A 2004 Tacoma Strut And Spring Assembly Bolt Into My 1997 4runner?
hello please advise
I have a line on assembled front struts out of a 2004 Tacoma
will these assemblies bolt into my 1997 4 wheel drive 3.4 liter SR5 4 Runner?
please help, I need to buy them quick if so, going on vacation in a couple weeks so I need to buy them, have them shipped and order some 892s for the rear and diff drop
given that these struts will fit my rig
thanks, tim
thanks, tim
they will be OK to use, but they may or may not be the same ride height depending on what they're coming off of. if they're off of a 4wd Double Cab or Extended Cab w/ a V6, then they should be about the same ride height as your stock springs (maybe up to a half-inch lower since they will be a touch softer than your stock springs).
Spring Rates:
Tacos ~430#/in
4runners ~450#/in
Tundras ~475#/in
Spring Rates:
Tacos ~430#/in
4runners ~450#/in
Tundras ~475#/in
06-01-2021 01:51 PM
