Which wideband and where?
I'm looking to put a wideband on my 99' 4Runner Limited (5vz-fe) since I think my front O2 sensor has gone bad. I'm planning to go boosted in the near future, so I'll need a wideband anywys.
Can I replace my stock O2 sensor with an aftermarket wideband? Will the computer read it ok? If so, which one should I go with? I don't mind if I need to cut the connector off the old (stock) O2 and solder it onto the wideband.
Update.
I have Califorina emissions (2 cat converters) so I think mine are actually A/F sensors (i.e. wideband) as opposed to the old style O2 sensors.
I guess there's no reason to go after market then if I already have widebands on there?
Yeah, you're going to have to replace the stock sensor.
The Innovate will help you when you go boosted to accurately monitor everything.
I would not recommend wiring a gauge to the stock sensors. Leave them alone and just get the Innovate kit and keep it stand alone.
skrassow
10
02-23-2013 11:00 PM
bone collector
02-17-2013 12:57 PM
Shogun1011
08-13-2007 07:07 AM
