wich color has the tachometer wire in 4runner 99?
I installed a viper alarm with remote starter and I cant find the tachometer wire , somebody knows? how to find it cause the remote start keep starting the engine and doesnt stop, even if its running the motor,,, thanks alot
voltage sensing?
i use to have the same viper alarm in a camry/ but the intaller doesnt remember the color tachometer wire, but maybe youre right, so how do you do that? how do you find the voltage sensing? the 4 runner start but keep starting and make alot of noise when remote starting!! tnx alot
you can also locate it by the black wire on the diagnostic port under the hood thats on top of the engine thats the one i used when i put my remote start and alarm in and it works like a charm
I pulled my cluster and tapped into the tach wire behind there - far better for a stealth install. I dont remember the color, but it was really easy to find with a meter.
I found the wire and now its remote start working ,,
yeah the black wire in the diagnostic worked hella good. all you gotta do afterwards is use some of that black tube wrapping and it'll look so much better and clean.
and thanks again for the pic Kerby J.
if anyone out there need some help installing a viper 5900 remote start into a 97 4runner lmk. i just got done with mine today.
MMA_Alex
25
04-18-2017 06:07 AM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 07:24 AM
