Whos got a Timing belt and water pump replacement write up?
Old 02-11-2010 | 08:37 AM
dgl4runner's Avatar
The shop wants to do it for $750, but i want to save some money and try to do it on my own. but I cant find a good write up.. lots of pictures are good.. im a visual person haha thanks for the help guys
its for my 98 4runner 5VZFE
Old 02-11-2010 | 08:45 AM
mastacox's Avatar
Just find the factory service manual for your vehicle. It will have everything you need, including pictures, step-by-step instructions, and torque specs for the bolts.
BTW: $750 is an ok deal for a timing belt and water pump job, as long as they were going to usa all Toyota OEM parts.
Old 02-11-2010 | 08:48 AM
mastacox's Avatar
Looks like you'll find the FSM you need in here: https://www.yotatech.com/forums/f128...-years-156128/
Old 02-11-2010 | 08:56 AM
Gerdo's Avatar
http://www.4x4wire.com/toyota/maintenance/timing_belt/
The big suck factor is the crankshaft pulley, off and off!
Old 02-11-2010 | 10:31 AM
Nuthuts96's Avatar
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
easily overlooked items needed:
crank pulley holder (you can make one) and; tensioner tool and;
HUGE 75-250ft/lb Torque Wrench (can be rented)
I did it myself because I'm a big believer in if I did it, I know it was done right (even if I'm learning along the way!)
pm if you have questions. i did it in a day... i had a thread around here somewhere on it.
Old 02-12-2010 | 11:27 AM
dgl4runner's Avatar
thanks guys, this will save me a ton of money!
voiddweller
19
05-02-2016 10:10 PM
vasinvictor
01-20-2016 01:39 PM
paxanders
06-21-2015 07:29 AM
Mutinebullfrog
06-18-2015 02:36 PM
infinityisfive
06-16-2015 07:51 PM
