Whinning noise
Whinning noise
I am a little concerned with a whinning noise my '94 3.0 is making.
The noise seems to be coming from the transmission area and it is most apparent when I am idling or as I am moving at slow speeds. The whinning increases as I accelerate but then disappers behind the engine noise.
I started to observe this this past weekend while out on a trail.
Gears are kicking in fine and usual.
Transfer case is as smooth as before and the lower gears are functioning appropriately.
I am getting good readings at the dipstick, as well.
Basically, I have not noticed or felt anything out of the norm, simply the noise is what I do not seem to recognize.
I was told it was the torque converter I cannot think of a reasoning behind that.
Any thoughts or ideas?
Thanks,
KING
Thanks,
KING
^^ lol
low fluid would cause a whine, as it gets going faster, the fluid goes everywhere as the pump pumps more. so at low speeds or idle, it may whine with low fluid =)
Originally Posted by TDiddy
Is there a girl in the passenger seat? I notice my wife's whining is louder at idle but also decreases with engine noise.
All belts look good and timing belt was just replaced 10K ago.
PS Pump is good.
Tell more about this fan clutch whine?
Yesterday as I was trying to nail the whine, it seemed to be coming from this area.
What does this indicate if indeed it is coming from the fan clutch?
The more I pay attention to the whine, the more annoying it gets.
PS Pump is good.
I actually had the same thing on my '96 taco, started one day for no reason. A friend of mine is a trannie expert and I had him take a look at it and he told me it was the transmission, it was just loud. That was about 60K miles ago, noise is the same, and no problems since.
Try sitting at idle with the windows down and then compress the clutch pedal. Does the whinning go away? If so, I would suspect it is from the trannie. Your clutch won't engage until the pedal is pushed, so you can rule that out pretty quickly.
Brian
Brian
Originally Posted by KING
Tell more about this fan clutch whine? Yesterday as I was trying to nail the whine, it seemed to be coming from this area.
hope that helps.
Indeed, the whine goes in pace with the acceleration but then disappers behind the engine noise. When I deccalerate, the whine takes a while to come back again.
My truck is going to ge going to the dealer soon for the steering recall so I'll have him check that and fix or replace what needs to be done.
My truck, by the way, is automatic and not standard.
zytra
01-24-2019 03:16 PM
zombie_barbarossa
10-02-2015 10:54 PM
