Wheel spacers questions, pic inside...
Old 05-02-2004 | 10:14 AM
UNR.Grad's Avatar
Until I get alittle more money, can I run these spacers to make my wheels stick out farther. I am currently lifted 2.5 inches, but dont have the money to buy new wheels which have a better offset to fil the fender flares. So could I run 2 of these 1/4 spacers on each corner to fill the fender flares a bit more, just until I have the money to buy new wheels and tires? Or I also have the option of buying 1/4" TO 3/4" THICK HUB CENTRIC FLAT SPACERS for $40 EACH from this guy who custom makes them to a vehicles specs, but they are also a bit costly? What would you do?
How much space can I add before I need new lug bolts?
Thanks
Tim
Here's the spacer, just a generic spacer:
Old 05-02-2004 | 11:01 AM
4runner4ever's Avatar
You don't have enough thread left for two spacers. Get a pair of decent rally spacers. I run 1 1/4 inch for over 8 years now without any problems.
Old 05-02-2004 | 11:25 AM
turboale's Avatar
I would save the money and wait for wheels personally...
Old 05-02-2004 | 11:34 AM
deathrunner's Avatar
Go to www.protrux.net
They have 1/2 inch spacers I believe. That would be much better than 2 1/4 inch spacers. I think they are 150.00 a pair. So if 300.00 is worth it to you to fill that amount of time....then go for it.
I think it is pretty crucial to get the spacers aligned right...or you might get wheel vibration or uneven wear. I think installation is alittle more complex than simply bolting on.
Old 05-02-2004 | 02:06 PM
UNR.Grad's Avatar
I think I'm just going to get a set of 1/4 inch generic spacers. I most likely won't see a difference but I want to try them and for $30 it's cheap
Old 05-02-2004 | 04:50 PM
Hyperlite's Avatar
All Pro Offroad has some 1.5 spacers that will make your truck 3" wider for $99
All Pro
Old 05-02-2004 | 04:58 PM
tenfourtyeight's Avatar
The ones Hyperlite posted are the way to go. I know several people that have had them on for years, and they still don't have any problems, even after dozens of trips hauling ass and jumping in the desert.
Old 05-02-2004 | 05:54 PM
UNR.Grad's Avatar
All Pro
So it would be $200 total? Or is it $100 for all four?
Old 05-02-2004 | 06:00 PM
The link above the pic says it is per pair. So $200 for 4 spacers.
Old 05-02-2004 | 06:12 PM
934rnr's Avatar
Just 2 and what people don't tell you is aluminium spacers will loosen up with steel wheels they need to be torque checked often.
Old 05-02-2004 | 09:02 PM
motrhedx81's Avatar
I'm running 2" spacer from StageWest4x4.com. Call em and they will make whatever size you want. I did pay $320 for all four though. I rather be wider than rollin over when I take a sports-car-corner in my truck with about 5" of lift anyday. But like Turboale said, I'd save my money and buy new aluminum wheels and get the spacers then.
Old 05-16-2004 | 10:55 PM
UNR.Grad's Avatar
Someone mentioned balancing spacers is crucial, how hard can it be? Any tips?
09-04-2015 10:27 AM
rushw
07-18-2015 02:46 PM
87turboPA
07-12-2015 08:49 AM
Yotoder865
07-09-2015 08:51 PM
