Whats the Worst that Could Happen
I was in a hurry when coming off a trail the other day and forgot to disengage 4wd (high) and proceeded to drive about 4 or 5 miles at 70 mph before i noticed and turned it off... what could happen if anything?
I've been noticing a rubbing sound when turning but i think that started before and i'm paranoid.
sounds like you better start checking these things whenever you leave the trail, as that could definitely cause some damage if you would've kept on driving. but i just posted something on your other thread about the "rubbing" issue...
as others have mentioned, you can drive all you want in 4WD HI, shouldn't be a problem at all. As a matter of fact, it is even recommended to drive 30-50 miles per month in 4WD so your gears will be properly lubricated.
83yotastockR
11
11-10-2015 06:54 AM
zombie_barbarossa
10-02-2015 10:54 PM
