what's the deal with coil spacers?
#41
Originally posted by Hyperlite
They make custom make coilovers to any size you need. Yes to your question, but only for the rear. All it takes is some fabrication.
There is a BIG difference in the suspension of your solar car and a 4Runner.
Hmmm...this is proving to be a much greater challenge than I thought. I see exactly what your train of thought is, you're saying the spacer makes the spring stiffer and doesn't let the shock compress as much as before. This is incorrect .
Ignore the process of installing the spacer. We don't care about the condition where the coilover is outside of the truck. Just focus on when the coilover has weight on it. When the weight of the truck is on the coilover, the coilover is not fully extended...it's kinda floating there somewhere between fully compressed and fully extended. The 2in spacer just extends the shock by 2in but it is still not fully extended. If the spacer indeed compresses the spring by 2 inches then there would be no lift because the shock is at the same length as before.
Another way to think of it, take 2 identical coilovers but one has a 2 inch spacer installed. Install them and measure the height of the springs and only the springs. You will find the spring height is exactly the same, but the shock is extended by 2 inches.
Let's try to go about this another way. Earlier you said that adding a spacer to the rear coils will not add preload because it's "added for height." I think you do understand the principle in this case...the spacer just shifts the truck higher relative to the spring. Well this is the same principle as coilovers, spacers just shift the truck higher. The only difference between a coilover and regular coils is the location of the shock.
Before you respond, please think carefully about what I have said in this thread and how it relates to figure 1 of my article. I think it will eventually make sense.
#42
Originally posted by OneTrickToy
Okay, I don't want to dog on you.... but you are contradicting the laws of physics. If you are in school, take this to a physics teacher for an explanation. The pack will only add it's own weight to the compression once the vehicle is added. This is rudimentary physics.
#45
ok, i have a question concerning lift springs and coil spacers combined. Do you think it would be a good idea to add coil spacers with my 4" rear lift springs? Like some Daystar 1 1/4" or 2 1/2"? If so could i go with the 2 1/2" spacers? I know i will probably have to get longer limiting straps but thats fine. Its just that my 4Runner still sags like a mug and i'd like it to look a little better. Thanks, Jake
#46
I don't know about the practical side of lifting higher than 4" with spacers (like will the spacers fall out, control arm angles, etc) so I'll let somebody else answer this one. As far as the springs are concerned, I don't see anything wrong with it, but again, I'm not sure at that height.
choppe777
05-16-2016 08:00 AM
Rickstwowheels
09-09-2015 06:12 PM
LJR
09-05-2015 06:02 AM
