What type of differential fluid?
Old 01-29-2008, 12:46 PM
jim1000's Avatar
I have a 1999 4Runner SR5V6 2WD.
I wanted to change the diffferential fluid and wanted get recommendations for type and grade of oil. What do you recommend?
Old 01-29-2008, 12:49 PM
MadCityRich's Avatar
The owner's manual is a good place to start. It has the grade listed for each of the driveline components.
I'm personally using a Amsoil and Redline in my diffs and transfer case because I've had it sitting around the garage. I'm a fan of synthetics. Any synthetic will be plenty good. Check out Mobil 1 and Amsoil. I've found them the easiest to locate.
MadCityRich
Old 01-29-2008, 01:17 PM
rdlsz24's Avatar
Mobil 1 since it's readily available.
Rob
Old 01-29-2008, 03:10 PM
Guest
seanz0rz's Avatar
rear diff: 80W90
i will be switching to synthetic, but conventional will be ok if you are not hard on your vehicle.
Old 01-30-2008, 04:37 AM
mkgarrison5's Avatar
75/90 or 80/90 weight is fine BUT if you tow or 4 wheel a lot i would really look into a 75/110 or 75/140 weight for extra protection.. preferably a syn in those higher weights.. amsoil, mobile, redline are good ones..
justdifferentials
14
06-11-2017 08:36 PM
Swampwalker
10-12-2015 09:49 AM
old87yota
09-09-2015 12:39 PM
Badfish740
09-04-2015 04:21 AM
Quick Reply: What type of differential fluid?
