What Transmission was behind the Supercharged 3.4L?
What transmission would have been used behind the supercharged 3.4L in a 1999 Toyota 4Runner Limited 4x4 Automatic? I am looking for the Code, or any other information. IE Full time 4x4 or part time etc etc. Please help if you can!
Thanks
Rob
Thanks
Rob
I think the 1999 has a different transfer case but the transmission is the same - A340F.
that's where the difference lies because of the multi-mode 4WD option that was available in the 1999 and later 4Runners. and as stated above, all 3rd gens are part-time 4WD.
So are the differentials different or basically what I want to know is can I swap this transmission and transfer case into a 1998 without any difficulties? I know there are dash switches that vary but what else?
the differentials have differences on the gear ratio and some rear diffs have the e-locker. however, these will not affect your tranny and t-case swap. with the new t-case, you'll also need the transfer lever that came with the new t-case but is attached to the tranny.
then you'll need a shorter rear propeller shaft and a longer front propeller shaft to accomodate the longer multi-mode t-case. the angle of the rear propeller shaft is now steeper so you'll need the one with a double-cardan joint at the t-case side.
i don't know if there are addtl electronics (oher than wiring and switches) needed for the addtl sensors in a multi-mode t-case
hth
hth
kelly1450
09-02-2015 01:29 PM
anniesball
07-29-2015 12:46 PM
