What is this switch in my fuse box?
I found this when I opened the fuse box. I don't know what either the black box or the switch with in the bottom right corner is. The joy of used vehicles. At least it runs really well. Thanks in advance.
I had a 98 Taco that had an alarm with a toggle switch. I never had the key fab to activate the alarm and never really understood what the toggle switch would be used for. Is there a siren under the hood? If so, try and follow the wires from the siren to the black box.
Could be a cheap remote start too - they often come with a switch to enable/disable the start feature, but shops hardly ever actually install it. It's a 'safety' thing...
It def looks like an alarm brain box, if you can get a model # off the box you can get a fob for it. I was in a similar situation and turned out the PO had a DEI remote start alarm installed but lost the fob so they disabled it before they traded it in to the stealership. I got a new antenna and fob and now I use it daily....love the remote start in this TX heat!
Thanks for all the help and ideas. I thought with it being saturday I would have some time to tear into it today. Now the wife wants to go into San Diego (2 hrs away). Also good but not would I would have picked. I'll let you guys know more later.
So it definitely is a car alarm. The brand is KARR. I can get the fcc id but I cant find the model number. I'm assuming that the switch is for the valet mode. I had the battery disconnected while I was doing some other work and now whenever I hook up the battery the alarm goes off. I don't have the fob and putting the key in the ignition/door doesn't turn it off. If there is a write up on how to take them out I would be happy to go that route. Right now I would just be happy to get the alarm off and my truck started.
if you have the FCC id just buy a fob for it here:
http://www.remotesandkeys.com/search...s.asp?cat=4256
no sense in un-installing it if it obviously works, just pull the fuse till you get the fob (unless that trips the kill switch)
