What oil filter?
Old 01-23-2005 | 06:33 PM
Ironmike4x4's Avatar
Originally Posted by jct61765
What oil filter is everyone using? I've always used Fram, but I want to know what everyone else is using.
Thanks
All I ever use is fram. It's not the filter that makes too much difference. I know this now after an API expert visited our school this past week and he was saying oil quality and filter quality doesnt really change much from brand to brand. It all depends on as long as you change them at regular intervals. I've been told by several technicians that oil filters dont matter too much as long as you change them often as you do your oil just so it doesnt get clogged up with gunk or particles. So reguardless of everyone's "opinions" any type you use is fine as long as you change them.
Old 01-23-2005 | 06:58 PM
ssyota's Avatar
Originally Posted by mt_goat
How much are those Amsoil filters? Mobil 1 is a great filter too but at $11 or $12 each, I'll pass.
I always ran the k&n with mobil 1 But now I switch to AMSOIL oil and AMSOIL super duty filter. AMSOIL series 2000 0w-30 oil & sdf 57 filter. I can get you one for 8 bucks plus s/h.
http://www.puresynthetics.com
Old 01-24-2005 | 08:24 AM
Ducky's Avatar
Mobil 1 Oil and Mobil 1 Oil filter =D
Old 01-24-2005 | 04:22 PM
95ToyotaPU007's Avatar
I used Toyota the first 30K miles. From there on I have been using FRAM. I just couldn't make it to the dealer to get the filter since my hours are different then their's.
I am currently using FRAM PH3614. Is there another filter out there that offers more filtering? Don't mean to steal your thread. I don't want to relocate my filter either.
Old 01-24-2005 | 04:38 PM
  #25
jct61765's Avatar
Nope, thats fine, I am curious myself.
Old 01-24-2005 | 06:59 PM
  #26
ssyota's Avatar
Just my opinion.AMSOIL. Check it out.
https://www.amsoil.com/storefront/sdf.aspx
Old 01-24-2005 | 09:39 PM
  #27
kyle_22r's Avatar
fram filters are terrible, because they let the oil drain back into the engine after it stops. this allows the engine to run dry when starting for much longer than other filters. i use a WIX 1515 filter, which is larger than stock but works fine, and holds oil in it while the engine isn't running.
Old 01-25-2005 | 06:03 AM
  #28
Ilovemountains's Avatar
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html take a look for yourself!
Old 01-25-2005 | 05:17 PM
  #29
ssyota's Avatar
Originally Posted by Ilovemountains
That's very interesting. I would like to see what the k&n filter would do and what the out come of the AMSOIL is.
Old 01-25-2005 | 09:21 PM
  #30
Dosnt matter
if you want to get technical after about 500 miles the oil filter has a bypass valve and and the filter clogs and bypasses it so any oil filter is crap in my opion
Old 01-26-2005 | 02:41 AM
  #31
epic37311's Avatar
Originally Posted by SizzleChest
you guys that are using toyota filters, are you still able to buy the japanese made filters? the only ones that I can get are made in thailand. 22re.
I don't know mines 83 factory
Old 01-26-2005 | 05:28 AM
  #32
Thumbs down dude, that makes no sense at all!
So you are saying that after 500 miles, with clean oil that the filter element gets plugged up and the bypass valve opens, making the filter into nothing more than an open tube for oil to flow through.. sorry dude but you are wrong on this one. So when your driving down a dusty road, 500 miles later your air filter plugs up and your engine shuts off?
Old 01-26-2005 | 03:22 PM
  #33
Tacotex's Avatar
Wix, Toyota oem, AC Delco oil filters exploded
Looks like the oem wins:
http://theoildrop.server101.com/ubb/...c;f=6;t=002099
Eggslinger
06-08-2019 04:32 PM
jasonty
41
12-23-2018 02:00 PM
calderp
Engine Swaps
08-16-2016 06:15 PM
calderp
07-27-2015 10:58 AM
ryerye13
07-14-2015 09:27 AM
