what kit is better?
what kit is better?
hey i want to know which kit is better for my 91 pickup? the procomp 4inch for the superlift 4 or 5 inch? Cuz i can get the procomp lift for a couple hundred dollars less than the superlift but if the superlift is worth the money then ill pay for it.Thnx alot
The Superlift is better 'cause it has a stronger set of drop brackets and crossmembers.
That said, I wouldn't buy either lift unless you just want the extra height for the looks and to fit bigger tires. Those lift's make an IFS truck waaaayyyy too unstable for any serious 4 wheeling.
I have a pro compr front end and I like it, ya not as good flex and such for wheeling, heck it's ifs, waht do you expect. BUt it keep the ifs origional geometry, which if u ask most people here is the best suspension, stock... either one will do u good, if u want 33's just go with the pro comp, if you want 35's you can do a 1in body lift with the superlift 5 in and presto.... Its all what u want it for...
sonorn67
09-19-2015 05:39 PM
JookUpVandetti
09-17-2015 09:25 PM
