what is the charcoal canister?
Old 10-03-2009 | 09:00 PM
burton6509's Avatar
i have a 02 4runner and i have been getting a ticking noise coming around the brake fluid area.. and i was at the dealership the other day picking up some parts and i asked a tec what was the ticking noise and he said it was prolly that
what is it? and could this be replaced easy?
Old 10-03-2009 | 09:30 PM
98runner210's Avatar
Charcoal canister is the sqaure box with two round circles on it. It filters gas fumes from the gas tank before releasing them into the atmosphere. Normal sound. Usually sounds like a buzzing.
Old 10-03-2009 | 10:20 PM
taandctran's Avatar
I had a 96 eclipse and it made the same noise. I was told it could be changed but I never changed it and it never game me any problems
Old 10-03-2009 | 11:34 PM
brian2sun's Avatar
http://bugeyebug.googlepages.com/4runner-evapbuzz
The part to fix it has been discontinued but TRDparts4U (that's his YT name) found me one. He can probably help you out too.
Old 10-04-2009 | 12:12 AM
FogRunner's Avatar
In the 01 and 02 4runners the charcoal canister was moved to the rear right above the spare tire. The pulsing noise your hearing is normal, there is a valve that opens at idle and other speeds intermittently for emissions control.
The noise is normal and unless you have a check engine light, don't was the $$$ replacing the canister. What the old saying don't fix it when its not broke.
Old 10-04-2009 | 12:53 AM
I'd like to get one. I don't care about the noise but people are constantly coming up to me at work telling my truck is making some sort of "shorting out" noise. (my parking spot is in the parking garage right by the door)
Old 10-07-2009 | 06:33 PM
burton6509's Avatar
i guess that it must not be the canister... it is a pretty loud ticking noise coming from the eng. fuse box/ brake fluid area this sound cant be normal.
Old 10-07-2009 | 09:54 PM
FogRunner's Avatar
The valve that controls flow to the charcoal canister is right in the area by the battery and fuse box and when its open at idle makes a rhythmic ticking sound that changes speed with the engine RPM.
This valve is a electronically controlled solenoid valve and you can unplug it to confirm that is what is making the noise.
justdifferentials
Just Differentials
06-13-2022 08:40 PM
kawazx636
10-06-2021 04:03 PM
Linked2002
3.4 Swaps
7
12-15-2015 02:31 PM
Badlander
10-10-2015 09:05 PM
94whiterunner
07-12-2015 08:15 PM
