weird turn signal brake light problem
Old 10-26-2010 | 02:27 PM
onesojourner's Avatar
alright here is what the ole 4runner is doing:
lft turn signal
front and back lft are normal
RT brake light flashes too
brakes
left turn signal solid on front and black
no left brake light
tail lights are normal while head lights are on (other than the flashing brake light with lft turn signal)
I checked my trailer wiring harness and all seems fine. What should I check next?
Old 10-28-2010 | 12:11 AM
wyoming9's Avatar
Red face
You most likely have a bad ground in one of your sockets or a bad bulb that is trying to ground via the brake system.
I would look at the left side first
Old 10-28-2010 | 04:26 AM
iselloil's Avatar
On the passanger side rear,look at the harness on the frame where it passes over the rear axel housing.See its broken or rubbing the frame.
Old 11-05-2010 | 08:03 AM
The harness on the frame looks good I will check the bulbs.
06-01-2021 02:51 PM
Kalihi,HI
07-09-2015 05:29 PM
colinmil
07-06-2015 05:03 PM
Jnkml
07-06-2015 02:20 PM
karbin
07-06-2015 12:37 AM
