VSC / TRAC defeating - is anyone closer?
Old 02-01-2005, 02:38 PM
  #241
aowRS's Avatar
If the trac/vsc systems use the master and brake cylinders to control wheel rotation, then it seems logical the ABS would be tied in with this, and would be affected by any modifications to the VSC/TRAC systems.
At this point in the game, we've come to two conclusions. One, either the factory TRAC OFF switch from the 2WD versions will 'plug in', or two, we'll figure out which wires at the fluid pressure sensor (master cylinder) to interrupt with a proper switch.
I don't think anyone here faults Toyota for developing these two systems, but rather, that the manufacturer does not give the option to disable these setups. Many, many other cars and trucks out there come with some form of traction and stability control, but then also have switches to disable should conditions warrant.
Thank you for the thumbs up. I hope we keep the momentum.
Andreas
Old 02-01-2005, 03:15 PM
  #242
emplusten's Avatar
Brendon,
What's the story? Have you "broken the code" or havin' fun with us? I need to know if I can stop looking at Toyota's colorful wiring diagrams!
Bob
Old 02-01-2005, 04:33 PM
  #243
Ducky's Avatar
Originally Posted by emplusten
Brendon,
Bob
Well Alot of us are patient I hope ^^, I am waiting till my Brother in law pays me his monthly payment for the car that he bought from me, and has been paying for a long time so i can buy a switch... However, If you would like to send me 70 for the switch, Ill hop down and go pick it up today lol...
I am in thin 100% just waiting for fundage, so i can be the first to screw up... err try something out lol.
Old 02-01-2005, 06:00 PM
  #244
AdemaDude1960's Avatar
Hey...I tested it out again today and it still seems to be working fine...The only concern i have is that my message display center where it shows temp., compass, and Miles till empty is messed up....i refilled yesterday and today and my miles till empty will not reset itself, also the compass is reversed. North is now south and east is now west, and the temp is now in C instead of F...Any reason on why that happened? I didn't mess with anything that came close to that...I am making a Homepage right now so i can post up how i wired it and post the 6 pages on VSC/Trac/LSD in the Manual. I am waiting for my buddy to send me the pics and video we made and took of the process and the fun afterwards but i should have it by the end of the week. Believe me i would not pull one over on you because i hate VSC with a passion and would not want someone to toy with me on a way to rid my self of it. Yes if someone can let me e-mail them the videos i will do that because i don't think i have the capabillity to host them. I am downloading the video's on my friends Apple because i have no software for videos on my windows. Thanks guys
Brendon
Old 02-01-2005, 06:30 PM
  #245
aowRS's Avatar
Ducky
Just emailed you.
Andreas
Old 02-02-2005, 04:43 AM
  #246
aowRS's Avatar
Good prices for the TRAC OFF switch
I sent out a few requests yesterday and heard back a few different places. The first was from from Mike at www.toyota-parts.com. Here is the info:
Traction Control Switch 84988-06010 $41.80
It can be ordered through their online parts request function, or by calling: 888-272-8840.
The second response was from Greg at www.toyotapart.com. Here is the info:
Traction Control Switch 84988-06010 $41.71 + $8-10.00 shipping.
It can be ordered through their online parts request function, or by calling: 800-581-3033
Cheers,
Andreas
Old 02-03-2005, 04:55 AM
  #247
aowRS's Avatar
Brendon,
Any info to share?
Andreas
Old 02-03-2005, 08:24 AM
  #248
aowRS's Avatar
For Mike or Bob
Mike/Bob,
Not sure which one of you has the factory service manual with schematics, but I wanted to see if you can identify the individual wires (1, 2, & 3) that form the three-prong plug at the fluid pressure sensor. I believe this may be a scan of the component, but I have not been able to definitively identify the wires.
Andreas
Old 02-03-2005, 08:56 AM
  #249
emplusten's Avatar
Originally Posted by aowRS
Mike/Bob,
I can do this once I get home from work tonight... Maybe Mike can do it sooner...
Old 02-03-2005, 09:23 AM
  #250
mikNtx's Avatar
http://community.webshots.com/album/254318478jhyxPZ
see “p3”
also, from an earlier post of mine:
“………anyway, as an interrupt for the master cyl pressure sensor, i would lean towards what appears as a ground "E2" or the signal + "PMC". "VCM" is a constant voltage (4.7-5.3V) with IGN ON. any seem viable as the manual says that the VSC is going into a "fail safe" mode. i just do not know……………..”
anyway, from “p3” diagnostic page, it appears PMC’s voltage varies as the pressure changes. disconnecting it should fail the ecu as it will output zero voltage. as someone suggested earlier, the use of bridging each circuit w/ alligator clips and shutting them down independently is the least invasive method to prove it works.
hope this helps.
mike
Old 02-03-2005, 09:40 AM
  #251
Simon's Avatar
mikNtx wrote:
...as someone suggested earlier, the use of bridging each circuit w/ alligator clips and shutting them down independently is the least invasive method to prove it works.
I tried that, connecting each wire one at a time, and could not see any diffrences. Then what I did was found a "3pst" switch that will open all 3 circuits at once. I haven't wired anything in yet, I was waiting to see what happened with the factory switch.
Old 02-03-2005, 11:02 AM
  #252
aowRS's Avatar
Mike,
Thank you. I may actually get some alligator clips and make three jumpers this weekend.
Simon,
Do you have a pic of this switch? As for the factory switches, I have one on the way, and another has been sent out to one of the thread participants...
Andreas
Old 02-03-2005, 12:29 PM
  #253
Simon's Avatar
The switch I was looking at is here, http://www.alliedelec.com/catalog/pf.asp?FN=769.pdf
Or you could just get a regular looking toggle switch cause there isn't to high of amps going through those wires.
Old 02-03-2005, 12:31 PM
  #254
Simon's Avatar
Oh yeah, the part number is SW3831 and I belive it looks something like the white switches they have on the page.
Old 02-03-2005, 12:40 PM
  #255
aowRS's Avatar
Interesting. So I assume the back of the switch has six posts? I ordered one of the factory TRAC switches, and hope to still make it work - either as a direct plug in via Ducky's research, or as an interrupter to one of the three wires.
On the other hand, it may very well be that all three need to be interrupted at the same time in order to achieve the result we are looking for.
Cheers,
Andreas
Old 02-03-2005, 12:49 PM
  #256
Simon's Avatar
From what I could tell, I think all 3 of them need to be cut at once. I tried connecting just one of the wires at a time with allegator clips (there wasn't enough room to get 2 allegator clips, at least not the ones I have, into the plug) So I don't know what would happen if you could connect just 2 of the wires. Maybe Ill try this weekend. And yes, I believe that switch would have 6 post on the back.
Old 02-03-2005, 12:52 PM
  #257
TacomaTRD's Avatar
you need to try having two connections at a time and disable one, if there is a ground in there then having only one connection won't do anything like you found out.
I would disconnect only the VCM line and leave the other two on. JMO, I'm an electrical engineer but that don't mean jack...
Old 02-03-2005, 12:53 PM
  #258
aowRS's Avatar
Simon,
I think this would be appropriate, mounted prominently on the dash in plain view:
J/K. Wrong switch style anyway.
Andreas
Old 02-03-2005, 12:59 PM
  #259
aowRS's Avatar
TacomaTRD,
Thank you for the input. VCM would be the #1 wire, black. Or so I think. One more day and the tinkering can begin, again.
Andreas
  #260
Simon's Avatar
I saw one of those switches at Radio Shack the other day. Looks like we would be launching missiles.
I agree with "TacomaTRD" that we need to try leaving just 1 wire disconnected, but like I said my allegator clips where to big to do that.
Quick Reply: VSC / TRAC defeating - is anyone closer?
