VSC / TRAC defeating - is anyone closer?
#221
More info (page 05-312) ...
It seems that if I had a 'hand held tester' I could plug it into DLC3 and run 'active test', 4 of which do the following:
ITEM Vehicle condition/Test details
SRCF (SA1) Turns TRAC solenoid SRCF (SA1) ON/OFF
SRCR (SA2) Turns TRAC solenoid SRCR (SA2) ON/OFF
SRMF (SMCF, SA3) Turns TRAC solenoid SRMF (SMCF, SA3) ON/OFF
SRMR (SMCR, SA4) Turns TRAC solenoid SRMR (SMCR, SA4) ON/OFF
All 4 tests cause the operation of solenoid (clicking sound) can be heard.
I'm guessing that the last character in each item is Rear or Front.
Reading other pages tends to indicate that SRC, SPC, SRC, and STR are directly related to the brake master cylinder which seems to jive with whatever occured in the test that Andreas performed.
DAMN! There is a TRAC OFF BUTTON TO THE RIGHT OF THE CENTER DIFF BUTTON in this manual!!!
I started using my head about links and decided to use my old web server that lies idle ...
2003 TRAC details are in the following PDF which was extracted from the 2003 repair manuals:
http://www.synertech.com/chris/2003_...iagnostics.pdf
I think a call to the dealer is in order ... hopefully to place an order for a TRAC OFF button!
#222
Very interesting Chris. I just do not understand why Toyota would equip some vehicles (3rd Gen & 4th Gen) with this switch, and not others. That seems to add validity to an earlier comment that ECUs and such may in fact be the same between 2WD and 4WD models.
The search goes on.
Andreas
The search goes on.
Andreas
#223
I pulled the switch covers out on mine today and there are two wiring connectors in there, one black and one blue. I don't have any books, so I can't tell you what they are for, or if anything else besides a switch is missing to activate them.
#225
Originally Posted by aowRS
Bob,
Interestingly, someone a while back posted that when they pulled this sensor connector on their Sequoia, they retained ABS, yet were able to disable TRAC and VSC.
Andreas
Andreas
Brendon
#226
Strangley enough, i had to pull the 4wd fuse, start the engine, flip my switch which disengaged the VSC/TRAC, turn it off and put the fuse back in after it started it again and it seemed to work.
No idea why it works the way you describe though.
Andreas
#227
I have an 04 Sequoia and i tried pulling the sensor while the truck was on and i did lose the PITA VSC/TRAC but i had next to no braking what so ever.
This is from a member of 4X4Wire regarding the same issue:
"On my wifes Sequoia I unplugged a sensor on the brake master cylinder. This disabled the VSC and traction control but the ABS functions normally. On the Sequoia it was the sensor farthest forward and on the bottom of the master cylinder."
Andreas
#229
Simon,
Sounds good. By that I assume you pulled the pressure sensor connector?
I think the name "AndyMod" will only have validity when we figure out which of the three sensor wires to interupt with a switch. Until then, it's just backwoods shadetree mechanics...
That is, unless Mr. Ducksworth figures out how and where to plug the factory TRAC OFF switch that I would like to reimburse him for....
Andreas
Andreas
#232
YUP!
worked like a charm. didnt even realize my runner was capable of such freedom.
i overdid actually and skidded kind of scarily at one point, but all is well.
#233
scans of the center diff lock diagnostic circuit "di" are uploaded at:
http://community.webshots.com/album/254318478jhyxPZ
#235
How on earth did you figure that flow chart out??
Andreas
Andreas
Brendon
#237
Hi Brendon,
I can feel the glee in your post about being able to disable TRAC in your Sequoia. I'd be interested in your pics, movies, and anything else you have on the subject. With your permission, I could also store them on my web server and post them to the VSC/TRAC thread for others to enjoy.
Either way, could you please email me the files? PM sent.
#240
I may be a little out of turn here, but all this discussion seems to be focused around getting the wheels to spin. If the trac/vsc systems use the master and brake cylinders to control wheel rotation, then it seems logical the ABS would be tied in with this, and would be affected by any modifications to the VSC/TRAC systems. This banter is great though. Seems like the best solution might be along the lines of disabling the thing completely. Considering the trucks in question all have slush boxes, ABS would be a good thing on steep creepy hill descents
IMO ABS is bad off road, I got a little surprise in my company truck a while back, sometimes while driving on dirt I go a little fast and slide through corners. Imagine my surprise when the little blazer I was driving didn't slide, kept going straight, I did something quick and barely missed a cactus. Evil ABS...... make butt pucker!
This makes me think I may want to be able to disconnect the ABS on my 2nd gen for situations where I want to slide.
Good luck and GREAT work
